Wiring Question - MOPAR TECH out there..
Old Nov 10, 2010 | 08:50 AM
JohnVI's Avatar
JohnVI
Default Wiring Question - MOPAR TECH out there..
When you use the Remote start the inside electronics come on, however things off of the ignition do not. The DVD headrest setup I have doesn't come on with the remote start. Does anyone know if it is possible to change the wiring to have my DVD headrests come on with the remote start, and stay on when the key is inserted?
I'm not sure if this is possible without some type of voltage sensor. If the wire that has 12volts is live when you activate the Remote Start, it might go dead when the key is inserted....
Anyone a MOPAR technician
Old Nov 10, 2010 | 02:28 PM
JohnVI's Avatar
JohnVI
Anyone
Old Nov 12, 2010 | 07:06 AM
JohnVI's Avatar
JohnVI
Default What Wire provides 12volts during & after remote start
The wire I need to find is the wire that when you activate your remote start it has 12volts, but when you put the key in it stays at 12volts. The wire can't give 12volt unless the remote start is activated OR the key goes in and the accessory position or ON is turned...
any takers?
