esp question for the guru's
Old Nov 22, 2010 | 05:04 PM
jayman84's Avatar
jayman84
Default esp question for the guru's
How can we disable the esp completely while in 2wd. I have tried talking to my dealer to see if they can do it through the starscan and no one will even look to see if it is an option. I have a 4wd truck and i want to be able to turn it off 100% when in 2wd and all i can find is to pull a wheel sensor and then lose abs and that is not an option. Any help would be awesome.
Old Nov 23, 2010 | 02:27 AM
canadian dakota's Avatar
canadian dakota
who needs ABS seriously every vehicle ive ever owned hasn't has ABS and im still alive as for the ones ive driven (company chevys) with ABS i dont like the feeling its almost as if i dont have control of the vehicle just my 0.02 all im saying is take the sensor try it with out the ABS and see how it feels if you dont like having control put the sensor back in
Old Nov 23, 2010 | 12:28 PM
tombogue09's Avatar
tombogue09
The "key trick" is another method of turning it off. I don't know if you want it off all the time or just a brief period but the key trick works perfect if you just want it off for a short time. Just turn the key to the starting position and hold it there, esp will be completely disabled as long as you hold it.
Old Nov 23, 2010 | 05:35 PM
canadian dakota
Wait did I understand that correctly as long as you hold the key so drive while holding the key..... That seems rather inconvenient lol
Old Nov 23, 2010 | 05:41 PM
devile's Avatar
devile
duct tape will help with inconvenience... LOL
Old Nov 23, 2010 | 07:26 PM
tombogue09's Avatar
tombogue09
Thats why I said its a good method to use if you want esp off for a brief period, like when you get stuck. I see no reason why you would want it off all the time.
Old Nov 23, 2010 | 08:35 PM
canadian dakota
LMAO!!!!! not that i want duct tape residue on my new column lol
lol i dunno i guess these rams are a little more hightech than what im use to
Old Nov 24, 2010 | 03:31 PM
POWER SEDAN's Avatar
POWER SEDAN
Should of gone with the Diablo tuner, it can overide the ESP 100% under modifiy tunes menu. Otherwise, (correct me if I'm wrong) I believe it's fuse 17 will disable the ESP as well. I can't remember for sure, but I believe #17 was the one I pulled before running the dyno last spring (been awhile), had issues in second gear start with ESP abled.
