weird noise when stopping
Old Nov 29, 2010 | 09:22 PM
canadian dakota's Avatar
canadian dakota
Default weird noise when stopping
i dont know how else to explain it but when i come to a stop there is usually a delay from the time i come to a stop and then there is a soft thunk kinda like something is rolling against the front of the bed but its coming from underneath has anyone else noticed this. im supposed to go into the dealer this week to have some decals removed that werent done and i was gonna bring it up. im just seeing if anyone else has heard this
maybe im just paranoid cause she only has 200km on her
thx for any input
Old Nov 29, 2010 | 09:28 PM
Attono's Avatar
Attono
I have the same thing. The Jeep WJ I had did the same thing. There was a TSB on it and it was called "stop bump". What was happening was the the slip yoke on the rear drive shaft was binding and then when you stopped, it would release tension and when it released, it felt like a little bump. The fix was to take the drive shaft off and put a bunch of moly grease on the slip yoke and then put the DS back on. Problem solved. I haven't crawled under mine yet, but I bet that's the problem.
Old Nov 29, 2010 | 09:47 PM
canadian dakota
its pretty consistant so im sure if i go for a ride with a mech i can get it to do it again if this is a problem is there a serious risk
Old Nov 29, 2010 | 11:01 PM
BigBlueEdge's Avatar
BigBlueEdge
Do some searches, there are lots of discussions about it. The best explanation I've heard, which matches my experience, is that it seems to be related to the gas tank and it happens most prominently when the tank is about 3/4 full. Every time I hear it I look down and sure enough, 3/4 full or so. Apparently at that level the fuel can slosh just right to cause a 'wave' moving around??
Rob
Old Nov 29, 2010 | 11:02 PM
Widespread's Avatar
Widespread
I hope its not your tranny.
Old Nov 30, 2010 | 09:27 AM
sully0263's Avatar
sully0263
I'm having the same problem. When I come to an abrupt stop I here a clunk from the rear, I also here it when I hit a bump normally an off camber bump. Almost sounds like a loose sway bar. I looked under the truck and didnt see anything. The truck only has 5000km's on it. Going to get it checked out when I bring it in for an oil change
Old Nov 30, 2010 | 01:55 PM
guinnessboy's Avatar
guinnessboy
my bet its your fuel tank.....i have the same issue and after looking around many sites it seems the issue is in the 32 gallon tanks when there are around 3/4 full. its pretty weird when you first feel it because its like its lurching forward, but i notice when i run the tank down below 1/2 the problem goes away.
Old Nov 30, 2010 | 02:06 PM
tombogue09's Avatar
tombogue09
Mine does the same thing. I always thought it was the tranny but the gas tank explanation makes sense. I'll have to start checking my gas tank level when it does it again.
Old Nov 30, 2010 | 03:34 PM
05Dakotaho's Avatar
05Dakotaho
Another explanation is that the ABS on the rear wheels releases abruptly which causes a "thump" sensation but not much noise.
Old Nov 30, 2010 | 04:32 PM
canadian dakota
Widespread that what I fear but I am sitting around 3/4 Full on the 121l fuel tank dunno how many gallons that is. I'll fill her up on my way home and see if the problem goes away. It was the same story ths morning on my way to the shop though I'm still gonna have it looked at though
