Old Aug 6, 2015, 12:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Anyone purchase OEM Cruise Control switch from dealer?
Old Apr 14, 2011 | 01:59 PM
luckyshotbrooks's Avatar
luckyshotbrooks
Its cheap enough but I dont know if my truck is pre wired or not. I wouldnt even know how to instal it. Anyone know if the ST is prewired?
Old Apr 14, 2011 | 10:04 PM
GapRunr's Avatar
GapRunr
My very basic ST with vinyl seats and rubber floors was prewired. I bought a cruise control kit from Rostra, installed the switch in the steering wheel and plugged the three wires from the cruise switch into the terminal connector under the air bag and that was it.
But... The switch that came with the Rostra kit has three wires coming off of it. The switch from the dealer does not. The big trick with the OEM switch is finding out which wire goes where, and then finding the same kind of small terminals that are used in that terminal connector to make your own wires.
I'm working on an idea at the moment and if it works out I'll post about it here.
Old Apr 15, 2011 | 01:53 PM
luckyshotbrooks
Thanks for the info and keep use posted...Good luck
Old Apr 18, 2011 | 07:34 AM
bullitt5244's Avatar
bullitt5244
I have a idea i might try...... the journey,nitro etc has the same cruise control switch kit as our trucks. You can buy the steering wheel setup with the cruise control switch and the wiring for like 89 bucks. I think that might work from what i have seen.
Old Apr 19, 2011 | 08:08 AM
bullitt5244
Ok figured it out. I got a steering wheel from the local junkyard for 100.00 and took the harness and installed it in mine and it works. Note you have to remove the pins from the journey steering wheel plug and install the pins in the Dodge Ram one. Def. alot cheaper than buying the Rostra kit!!!
