TPS is flashing
Old Dec 9, 2010 | 10:37 AM
pdavis53's Avatar
pdavis53
I had the same problem when it started getting cold. I just went out first thing in the morning and checked the tire pressure. I think they where all around 30 psi. So I bumped them all up to 35 psi. After driving around for a while I checked the TPS reading in the EVIC and by hand and it showed 37-38 psi. I figured this was fine and left it this way and I have not had an issue since. Funny thing is my wives Jeep essentially has the same system and I haven't had a problem with it this year. The Jeep always wait's til we are on a road trip and then it goes off, it's annoying.
Old Dec 9, 2010 | 02:56 PM
rrdstarr's Avatar
rrdstarr
It is not bad to run tires at low pressures especially if you have snow on the ground. It gives the tire a better footprint for traction. Off road I have run at 12 PSI(Before TPMS) and didn't roll the tire off the rim.
