Spark Plugs Already
Old Jan 4, 2011 | 07:26 PM
1970Duster440's Avatar
1970Duster440
I've been a Mopar nut for years and as best I can remember Chrysler has been using Champion copper plugs for years. The article below I found on the NGK site and might shed some light as to why. Read carefully.
All things being equal, a more powerful spark will create higher cylinder pressure which will create more power. The power of a spark is determined by its voltage (more voltage = more powerful spark).
Aside from variables such as cylinder pressure and A/F ratio, the amount of voltage required to jump across the gap of a given type of spark plug is determined by the plug gap. A smaller plug gap requires less voltage to jump across the gap and a larger plug gap requires more voltage to jump across the gap.
There is a way to reduce the amount of voltage required to jump across the gap of a plug. By increasing the number of sharp edges that the spark can jump from and to (as in SplitFire and Torquemaster plugs) or by using an electrode material that is a more efficient conductor than the standard steel material (like platinum) you can decrease the amount of voltage required to "jump the gap". The only problem is that these "specialty" plugs will produce a less powerful spark than a standard plug will at the same gap. This means that, as long as your ignition system can provide enough voltage to jump the gap on the spark plug all of the time, with these "specialty" plugs installed in your car your engine will produce less power than it will with standard spark plugs. The only way you can regain the power lost with these "specialty" plugs is to open their gap out farther (a wider gap requires more voltage to jump the gap).
I've seen a number of cases where people have installed SplitFire, Torquemaster or platinum plugs in their car in the place of standard spark plugs and have complained of reduced power. In all of these cases the specialty plugs were installed using the plug gap specified for the car's original standard plugs (with the exception of the Torquemaster, whose gap is not adjustable). The reduced spark power due to the reduced voltage requirement of these plugs was the culprit.
Nissan DID address this problem by specifying a larger plug gap when using platinum plugs (0.039" to 0.044") instead of standard plugs (0.032" to 0.035"). In this case, the platinums will produce roughly the same spark energy as the standard plugs while providing an extended service interval (50K to 60K miles for platinums versus 20K to 30K miles for standards).
Old Jan 4, 2011 | 09:10 PM
chambers's Avatar
chambers
The newer 5.7 hemi is using ngk coppers as the OEM plug and I read on another forum from a tech that some of the platinums were causing the coils to heat up more than usual and throwing codes. Anyway my dad and I recently changed his over from the coppers to denso iridium long life plugs and he has had no issues. If you're really worried about the warranty stick w/ copper, but denso makes good plugs and the long life iridiums are supposed to be good for 100k miles.
