what makes the trx different
Old Jan 8, 2011 | 11:08 PM
sking's Avatar
sking
Originally Posted by bigred3297
oh... I thought you were referring to suspension lift kits..
Thats a leveling kit and your TRX4 is already equipped with a "leveling kit" from the factory. This spacer will put strain on your CV's so it's not recommended by the manufacturer. You could always put it on and then check for 4wd shudder and premature cv wear. If you dont have any issues, keep it on
He has a 2500 and it has no leveling kit or CV's, its a solid axle.
Old Jan 9, 2011 | 05:28 PM
bigred3297's Avatar
bigred3297
Correct..
Throw a 8" BDS on there and some 37's.... I bet you'll be riding high then
Old Jan 9, 2011 | 09:19 PM
mdram43's Avatar
mdram43
yea with no warranty, which completely defeats the point of having bought a new truck, haha. one day! until then I'm going to call on that leveling kit which I am completely skeptical about with all the mixed views on this forum
Old Jan 9, 2011 | 09:27 PM
sking's Avatar
sking
Your truck is in no way shape or form in any way like a 1500trx, two different style suspensions. The only problem you will have with a leveling kit on your truck would be the broken tie rod issue witch you wont read about on this forum. The 2010-11 heavy duty trucks are snapping tie rods after leveling kits and lifts, but some have snapped without any type of lift. If you want better info about your truck you would have more luck looking in the diesel section since they have the same suspension..
Old Jan 9, 2011 | 10:22 PM
mdram43's Avatar
mdram43
funny you mention that. when i was truck shopping, for the hell of it, a friend of mine dragged me up to the toyota dealer to look at tundras. they had a whole set up for american truck guys like myself, showing each part of the truck in the display and comparing they're parts to the american truck companies. every part including the tie rods were beefier, sad but it was quite the eye opener
Old Jan 10, 2011 | 05:04 PM
mdram43's Avatar
mdram43
http://cgi.ebay.com/ebaymotors/Dodge...Q5fAccessories
a link to the mopar leveling kit, says it wont work on the trx4
i just spoke with someone at topguncustomz, says the leveling kit should work fine on a 2500 trx just not the 1500
Old Jan 10, 2011 | 06:48 PM
bigred3297's Avatar
bigred3297
Well they know their stuff and have installed numerous kits as you can view from their gallery. Go for it.....
