Kenwood Dnx 7360 installed
Old Jan 22, 2011 | 03:41 PM
Hal_T's Avatar
Hal_T
There is also a steering wheel cable that allows you to use the steering wheel controls.
Old Jan 22, 2011 | 07:21 PM
Daniel#88's Avatar
Daniel#88
Any information out there in how to change out the speakers in the dash and doors? I am looking at buying Polk DB351 for the dash and DB651s for the doors.
Old Jan 22, 2011 | 08:06 PM
ridem high's Avatar
ridem high
Looks sharp!Great choice......
Old Jan 23, 2011 | 10:03 AM
03vulcan's Avatar
03vulcan
When you say repl standard unit what was the model? Do you want to sell if the touchscreen I am interested
Old Jan 23, 2011 | 11:29 AM
wmichell227's Avatar
wmichell227
Originally Posted by Hal_T
No cutting was required for mine and I'm sure Mimmo didn't have to do any cutting either. The unit is a standard "double din" size that fits large openings.
I forgot to mention that I have a seperate usb cable for software and background image uploads. All cables are ran into the glove box so everything is hidden.
Which radio did you replace? I have the REN unit, but it seems a little smaller than a standard double din....
Old Jan 23, 2011 | 06:02 PM
Hal_T's Avatar
Hal_T
I had standard AM/FM stereo with CD player. Double din size is standard. It will fit.
Old Feb 7, 2011 | 05:01 PM
Mimmo Catalano's Avatar
Mimmo Catalano
Guys to make the unit fit in place i had to cut a piece of metal as the MYGIGs are not 2din but a little bit smaller no wire cutting required i used the pac module, everything is plug and play, for the gps antenna as i have the alpine sound i could not use the center grill in the front as there is a speaker inside (as far as i know is empty if no alpine sound) so the gps antenna is in the right side of the dash.
Anybody can pls tell me how to remove the rear handle cover as i would like to move the camera there?
@vulcan03 the unit I replaced was a rer that i moved in my wrangler.
Old Feb 8, 2011 | 02:44 AM
mdram43's Avatar
mdram43
you guys are all ignorant idiots man. what he means is that all the aftermarket in dashes will not play movies while you the car is in driving, so your passengers cannot watch, there for why go through the trouble of putting in a tv to begin with? theres a way to bypass is so your passengers can enjoy the money you spent on upgrading to a tv for them
Old Feb 8, 2011 | 01:12 PM
Islandiver's Avatar
Islandiver
I like your install, pretty clean. Just not a fan of that U bracket mount for the camera. I can see that corroding away in the next few years. I'd rather see a hole drilled with a grommet and flush mount the camera.
Old Mar 7, 2011 | 12:49 PM
martinez189's Avatar
martinez189
The way I got to the tailgate handle was I removed the bed liner cover and the tailgate cover from inside of the tailgate. I know some people say to remove the tailgate handle before you drill the hole for the camera, well I didn't and pretty much just eyed it and managed to get the hole perfect. Just to let you know that the camera I used was long and just by luck didn’t get in the way of the tailgate handle mechanism. To avoid that I would recommend and night vision camera because they tend to me shorter in length.
