09-11 MOPAR 2" Lift
Old Jan 26, 2011 | 01:50 PM
sensor5's Avatar
sensor5
Default 09-11 MOPAR 2" Lift
I called my local dealer and was told Mopar offers a 2" leveling kit and 2" lift. The 2" lift is $900, but includes front Bilstein struts, new rear springs, rear Bilstein shocks, brake line brackets, and rear stabilizer bar parts. I know many, if not most, have problems with shuddering after installing a leveling kit. Wouldn't this lift have the same problems with shuddering without lowering the front diff, like 4" lift kits do? Wouldn't this kit need a little but of a diff drop too? I included a link to the MOPAR Performance Catalog. Page 245 in the catalog link below.
http://www.mopar.com/assets/pdf/cata...ts_catalog.pdf
Old Jan 26, 2011 | 03:41 PM
trashman139's Avatar
trashman139
from what i've seen in previous posts the new 2'' lift does have all the proper drops to make sure the cv joints dont wear down
Old Jan 26, 2011 | 03:59 PM
jake09's Avatar
jake09
I wouldn't spend the money on a full out 2" suspension lift..kinda stupid imo..I ran a leveling kit with no problems..you could also get the adjustable bilsteins instead of a spacer, which would probably work better..better yet just get a 4" or 6" suspension to begin with bc you always end up wanting to go higher haha...rough country now makes a 1.25" body lift that you can add to a leveling kit which is affordable and would look nice
Old Jan 26, 2011 | 04:20 PM
trashman139
guys are having problems with the bilsteins as well. i want my wife to be able to get in my truck higher is better but when you put close to 80 miles a day on it a 4 or 6 inch lift wont work for me. im looking to raise the front to level with the back and maybe a 285 70 r17 tire nothing crazy.
Old Jan 26, 2011 | 05:25 PM
jake09's Avatar
jake09
I ran a 2.5 inch spacer and didn't notice any shimmying really...a 2.5 inch spacer on stock suspension components is a little too stressful anyway..i think if you had 1.5 inch lift in the front with a spacer or springs then you wouldn't have any problems though. But if you have the money to spend for 2" then the suspension lift should be a better ride.
Old Jan 26, 2011 | 05:31 PM
sensor5's Avatar
sensor5
Basically, all I want to do is raise my truck a couple inches. I have a wife and 3 kids; 4 inches it too much. What it boils down to is I'm very concerned about having the dreadful shudder after installing a 2/2.5 inch leveling kit or installing the longer Bilstein shocks.
Old Jan 26, 2011 | 05:34 PM
sensor5's Avatar
sensor5
I'm running 285/70/17 right now on a stock suspension and they fit fine with no rubbing.
Old Jan 26, 2011 | 05:41 PM
jake09's Avatar
jake09
yeh i understand where you are coming from...what i have seen is that some people run them without any problems and some that have a lot of problems..I guess it's a hit or miss kind of thing. But two spacers are pretty cheap and you could get a 1.5" one so you could maybe lessen the chance of shudders. But you may be fine with a taller one. Most of the shudders that people complained about were occuring when in 4x4 mainly.
Old Jan 26, 2011 | 06:27 PM
Dustinmc15's Avatar
Dustinmc15
I just took 1.5 inch spacers off my truck, you can have them for $50 shipped. That should get you pretty close to level. PM if interested.
Old Jan 27, 2011 | 05:04 PM
Ironhayden's Avatar
Ironhayden
so i dont understand why you cant put the 2 lift on the trx if it replaces the struts up front they would be the same if its a trx or slt right. thats the only different. also does any one know if the front struts are adjustable of fixed to the 2" lift setting.
