Change Oil Indicator
Old Jan 31, 2011 | 06:08 PM
SolarPLEX's Avatar
SolarPLEX
Default Change Oil Indicator
Ive done a search with no luck, anyone know how to turn the change oil message off? i change my own oil and apparently more than factory specifies to.
Old Jan 31, 2011 | 06:40 PM
stlram's Avatar
stlram
Turn key on but dont start. Pump gas pedal 3 times then start. Should get rid of oil change message. I think you have to do this within the first 10 seconds but I usually wait until all the chimes go off first.
Old Jan 31, 2011 | 07:41 PM
Gary C.'s Avatar
Gary C.
If I'm not mistaken you have to turn the ignition back off after you pump the gas pedal 3 times...
Old Jan 31, 2011 | 07:48 PM
ridem high's Avatar
ridem high
That is correct.Turn the key to the on position,depress the gas pedal 3 times within 10 seconds,and turn the key to the off position.......
