Tire pressures sensor light and Running boards
Old Jan 31, 2011 | 08:05 PM
auburn97's Avatar
auburn97
Default Tire pressures sensor light and Running boards
Stupid light stays on. Sensor states back passenger tire pressure is low. Unfortunately, this is not the case. The pressure is the same on all tires. How to reset the light?
Trying to decide on running boards for the truck. Anyone out there have other pics or suggestions besides standard Mopar stock?
Old Jan 31, 2011 | 08:11 PM
Gary C.'s Avatar
Gary C.
Sounds like you have a bad sensor to me...
Old Jan 31, 2011 | 10:12 PM
newmexicoram's Avatar
newmexicoram
I went with the Dee Zee NX running boards. A little pricey but, they are solid and were very easy to install. Everything fit perfect on my truck. Didn't have to twist or push anything. Also, they flex very little when I use them to get my 200 lbs in the truck. They do hang down a little lower then I would like but, not too bad. I had to get them for my wife and I not to sure how they will work out when I go deer and elk hunting.
Old Feb 1, 2011 | 09:12 AM
TDTIPMO's Avatar
TDTIPMO
Yeah I'd say bad sensor or maybe lose connection. The sensors should auto calibrate themselves from what I understand. Not sure how that works though.
Old Feb 1, 2011 | 09:45 AM
auburn97's Avatar
auburn97
Thanks, I have to take it back to the dealer next week anyway, will make them fix it.
Old Feb 6, 2011 | 05:22 PM
ridem high's Avatar
ridem high
The wheel sensors are very sensitive.My light has came on before,checked pressures,and found 1 tire,drivers side front,to be 1 lb. lower than the rest,and it triggered the light.If you have allready checked tire pressure,then I would agree to on a bad sensor.....
Old Feb 7, 2011 | 04:06 AM
TDTIPMO's Avatar
TDTIPMO
I wish these damn things told you what tire was low. That would make life so much easier.
Old Feb 7, 2011 | 05:12 AM
TRXHemi's Avatar
TRXHemi
My TRX shows all four individually....me likey.....
Old Feb 8, 2011 | 06:06 AM
TDTIPMO's Avatar
TDTIPMO
Yeah I guess that's what I get for going with the SLT. Oh well, if I get out and look I can usually tell which one is low. Living in Alaska though, you don't want to be out side looking for too long sometimes...lol!
Old Feb 8, 2011 | 11:59 AM
HEMI5150's Avatar
HEMI5150
2009 dosent have the individual pressure display, the 2010 does
