Anybody get 4.56 gears put in?
It was a Toyota with stock 4:11's. The gear change returned some of my lost power/mpg and obviously helped turn a larger tire. If you haven't already, I would call around to both local and national gear vendors and get their ideas on what ratio they recommend based upon your towing/tire size/diriving habits. I called around and had quotes as low as a 4:88. Glad I went with the 4:56 as I could still tow and drive at highway speeds. 4:88 Would have left me running at pretty high rpm on the highway.
You doing that yourself or getting it done by a shop. what kind and how much are they, is it for a 4x4? Thinking of doing this upgrade but just doing a bit of investigating before.
i am having a performance shop that a buddy of mine owns put them in. he is charging around $700 for both the front and rear. i picked up usa standard gears for the front and rear with yukon mini install kits. by the time i am done should have around $1500 into it.
Yeah 05Dakotaho i remember seing a post somewhere on here where it had all the tire size comparison with the different gear ratio. Not sure if you had posted that but if yes it would be nice if you could post it here, i tried looking couldnt find it.
Check out all the "Calculators" on the side bar from this link.
http://www.4lo.com/calc/geartire.htm
Tire size / height calculator
http://www.miata.net/garage/tirecalc.html
I have Yukon 4.56, bought from Randys Ring and Pinion with the master rebuild kit. Total was 2200 installed, front and rear, with the diff fluids changed after breakin. No whine at all, had a trans and gear shop do the labor. I only have 35'' tires and it is way too much gear for any sustained highway driving. Need 37'' minimum for that much gear - IMO. Gear swaps are certainly not cheap...
