Front bumper fascia
Old Feb 24, 2011 | 04:59 PM
Medic1's Avatar
Medic1
Default Front bumper fascia
How loose is the front bumper fascia supposed to be? I just had my chrome bumper replaced due to rust issues and I now notice that the painted fascia that sits over the front bumper seems quite loose.
I don't know whether they broke a retaining clip or whether I just didn't notice how loose the fit was before. It just seems to have quite a bit of up and down movement now.
Old Feb 24, 2011 | 05:54 PM
WNDERR's Avatar
WNDERR
Mine is pretty stable......
Old Feb 25, 2011 | 12:46 AM
HEMI5150's Avatar
HEMI5150
If it were my truck, i would walk a round in the dealers lot and check some other trucks out and see if its as loose as yours.
Somethin dont dont to kosher to me if its that loose.
Old Feb 25, 2011 | 03:21 AM
awful knawful's Avatar
awful knawful
I do believe that there are clips on the back side in the center of the fascia, these clips slide into a slot. The clips on the bottom of the grille also slide in the same slot, making it tight. maybe they broke of one of the clips on the bottom of the grille, or didn't get the one from the fascia in the slot, it's possible I've done it. take the three or four bolts out of the top of the grille and tilt the top of the grille forward. you should be able to see if any clips are damaged or not in place.
Old Feb 25, 2011 | 11:55 AM
BigBlueEdge's Avatar
BigBlueEdge
Yes, one or more of those clips may be unseated. Right after I got my truck I had the front end apart a bit to put in HIDs and noticed that one clip on the passenger side at the top of the bumper facia was not fastened. Check them out and see if that's your issue.
Rob
Old Feb 25, 2011 | 03:01 PM
WNDERR's Avatar
WNDERR
I rechecked mine, while washing the truck today, and there is VERY LITTLE movement, if at all..... if your's is loose, they broke something!
Old Feb 25, 2011 | 10:08 PM
Medic1's Avatar
Medic1
Thanks for the responses. I will be heading over to the lot to check out some other Rams but as said above I am pretty confident they may have broken something either taking it apart or putting it back together......
Old Feb 25, 2011 | 11:45 PM
BigBlueEdge
A popped-out clip is not broken and is really easy to fix...
Old Feb 26, 2011 | 12:02 AM
72combo's Avatar
72combo
Not supposed to be loose then it would rub the fender and cause paint to wear. Mine is tight as possible, as if it was part of the fenders.
Old Feb 26, 2011 | 01:42 PM
John Valdes's Avatar
John Valdes
Mine feels loose to. They checked it and said it was fine. But it does feel loose to me. I just chalked it up to lousy craftsmanship.
