swapping out roof clearance lights
Old Mar 1, 2011 | 06:25 PM
mdram43's Avatar
mdram43
Default swapping out roof clearance lights
just picked up a set of smoked recons off ebay, unscrewed one but it seems like its almost glued? to the roof. it looks like there is a rubber gasket, but it seems that gasket is attached to the lights. anyone have any experience?
Old Mar 2, 2011 | 06:48 PM
mdram43's Avatar
mdram43
anybody?
Old Mar 2, 2011 | 07:39 PM
InterpunX's Avatar
InterpunX
i know recon recommends to put cilicone on the rim so it doesn't leak. If you put a lil film all around it should be like a gasket and you can wipe away excess.
Old Mar 4, 2011 | 08:50 PM
mdram43's Avatar
mdram43
O i will, but what im saying is that I cant get the stock ones off period, its as if they are glued on. Im trying to figure out how to get em off without damaging the truck
Old Mar 4, 2011 | 11:59 PM
stump3r's Avatar
stump3r
Use the search function, I could swear I remember seeing a thread on this somewhere.
Old Mar 5, 2011 | 12:03 AM
mdram43's Avatar
mdram43
roof clearance lights (aka cab lights)= yellow lights on roofs found on 2500 and bigger trucks
Old Mar 5, 2011 | 08:21 AM
InterpunX's Avatar
InterpunX
Not sure about dodge, i know the ford ones just pop off with a flat screw driver and snap right back into place. Just use excessive force and see what happens, only one way to find out.
Old Mar 5, 2011 | 09:32 AM
Gary C.'s Avatar
Gary C.
I put a set of Recon smoked cab lights on my '07 and had horrible luck with them. Even though the lights are "sealed" they kept getting water inside and corroding the contacts to the point the lights would die. After peeling 3 of them off the roof (I used a lot of silicone) to replace them I threw in the towel and purchased a set of OEM ones from Dodge (I had 15 freakin' holes in the roof to cover).
The OEM ones should be the same as any others, some silicone used to seal them to the roof. I would expect you should be able to work them loose if you wish to change them out, but I'd really caution you to think about using the Recons...
Old Mar 5, 2011 | 02:36 PM
InterpunX's Avatar
InterpunX
what type of bulbs do the oem and recon cab lights require
Old Mar 5, 2011 | 05:30 PM
huntergreen's Avatar
huntergreen
i know a few guys at work who did what you are doing, they all regretted it as they all leaked.
