how can i bypass the factory alpine amp
Old Mar 11, 2011 | 04:54 PM
budlight2384's Avatar
budlight2384
Default how can i bypass the factory alpine amp
I just upgraded my stock 6x9 with some infinity kappa I want to hook them up to a amp and bypass the factory amp. I have the alpine set up but no audio shop around fresno ca will do it. Is it that hard? Does anyone know how I can bypass it or if there's a kit I can buy to bypass the factory amp
Old Mar 12, 2011 | 01:26 AM
hemirae's Avatar
hemirae
Try Audio Innovations at Fresno. Ryan will gladly help you.
Old Mar 12, 2011 | 02:27 AM
budlight2384
Ya I went there they want me to buy a p.c.a kit (c2a Chy2). a amp kit and all the hi/Lo set up and they gave a prices of 390 I didn't know about them till I found them in the yellow pages they got some bad reviews but they seem to know what there talking about
Old Mar 12, 2011 | 10:29 AM
dakota_raven's Avatar
dakota_raven
Check with this guys!!!
http://stores.ebay.com/Integration-Solutions
Old Mar 12, 2011 | 08:51 PM
roberttheall's Avatar
roberttheall
(I did the same upgrade so this is how I did it) For the front door speakers, remove plastic cover near foot well next to door area, you will see a bundle of wires, the speaker wires are here too. find the correct colors they will be twisted to gether, not too hard to find, just cut away some of the tape around the bundle, cut the correct wires and splice in with new speaker wire and run to your new amp. For the rear doors remove the lower plastic cover on the pillars between the front and rear doors, there you will see another bundle of wires where you can find the speaker wires. the color codes are as follows;
Left Front door: + GY/VT -GY/YL
Left Rear door: +GY/LG -GY/DG
Right Front door: +DG/VT -DG/YL
Right Rear door: +DG/LG -DG/GY
Note: GY= gray, VT=Violet, LG=Light Green, DG= Dark Green, YL= Yellow
Old Mar 13, 2011 | 05:00 PM
budlight2384
[QUOTE=roberttheall;2445066](I did the same upgrade so this is how I did it) For the front door speakers, remove plastic cover near foot well next to door area, you will see a bundle of wires, the speaker wires are here too. find the correct colors they will be twisted to gether, not too hard to find, just cut away some of the tape around the bundle, cut the correct wires and splice in with new speaker wire and run to your new amp. For the rear doors remove the lower plastic cover on the pillars between the front and rear doors, there you will see another bundle of wires where you can find the speaker wires. the color codes are as follows;
Note: GY= gray, VT=Violet, LG=Light Green, DG= Dark Green, YL= Yellow[/QUOTE. Thanks for the info I'm going to do it this way after u hooked it all up did anything stop working on ur RER h/u
Old Mar 13, 2011 | 09:10 PM
roberttheall
[QUOTE=budlight2384;2445649]
I replaced the HU with a Pioneer Avic Z120BT., but nothing should stop working, as long as you only cut the speaker wires.
Note: if you ever decide to replace your HU, you should unplug the factory bluetooth device. I had trouble connecting my phone to my new HU, because my phone was still trying to connect to the factory blue tooth device, even though I had already removed the RER radio. I did not realize it was located seperate from the RER radio. the factory blue tooth is mounted in the inside the dash near the glove box, there is a plastic cover at the end of the dash when you open the front passenger side door, to get to it.
Old Mar 14, 2011 | 02:42 AM
hemirae's Avatar
hemirae
Default C2A-CHY2 instructions
http://www.pac-audio.com/PACProductD...ons_032608.pdf
Old Mar 14, 2011 | 05:48 PM
roberttheall
Good info, the pac product will provide the RCA outputs to run to the amp from the factory HU. However he will still need to run new speaker wire to the new spakers from the new amp to bypass the factory amp. I would suggest using some good quality 10 or 12 guage speaker wire for the new speakers.
Old Mar 14, 2011 | 06:11 PM
loansinpa's Avatar
loansinpa
It was just easier to run everything from scratch.
Put the amps under the rear seat and ran new speaker wires from there. Ran all the wires from the new head unit back to the amps & ran a new power direct up to the battery (for the amps).
I screwed around with JL converters, etc trying to mesh the old system into the new and it just felt like a waste of time. The big PITA is going from the posts into the doors with new wires. Other than that there is a lot of room to get around.
