Question about leveling kit issue
Old Mar 13, 2011 | 08:44 PM
moosey42's Avatar
moosey42
Default Question about leveling kit issue
Just installed a 2 inch leveling kit on my 2wd. Got longer shocks b/c factory ones were maxed out all the way. Problem is when I hit dip in road, upper a arm strikes side of coil bucket. My question is what does anyone think could remedy this problem, new upper a arms or grinding down the upper a arm alittle bit so it has more room to articulate downwards? Any suggestions would be great.
Old Mar 13, 2011 | 09:23 PM
dodge7's Avatar
dodge7
What kind of spacer is it
Old Mar 14, 2011 | 04:08 AM
trashman139's Avatar
trashman139
wow can't help but i would strongly suggest not grinding anything down on your truck.
Old Mar 14, 2011 | 02:41 PM
moosey42's Avatar
moosey42
Its the daystar.
Old Mar 14, 2011 | 05:59 PM
roberttheall's Avatar
roberttheall
I would suggest removing the leveling kit. if you really want it level you could also lower the rear a couple inches. , just and idea
Old Mar 21, 2011 | 01:06 PM
RAMHEMI07's Avatar
RAMHEMI07
Default 1.5" not 2" inch.
I put the 1.5" inch Daystar spacers in and have had no problems with grinding or shock extension. Can't help you with the 2".
I
Old Mar 21, 2011 | 05:09 PM
eclipsems's Avatar
eclipsems
Does anyone know if someone manufactures a 2" lowering kit for the rear instead of raising the front to level out our trucks?
Old Mar 21, 2011 | 10:15 PM
moosefire66's Avatar
moosefire66
Did you remove the coils in order to install these? If so, maybe you re-installed them upside down...?
