2010 ram engine question
Old Mar 15, 2011 | 06:39 PM
RumRunner's Avatar
RumRunner
Default 2010 ram engine question
I just picked up a 2010 ram with the hemi in it. Could someone enlighten me on what the cubic inch, horse power, torq specs are on these engines.
Old Mar 15, 2011 | 07:42 PM
USAF1's Avatar
USAF1
Thats all on the Ram web site from Chrysler. It even has a graph to show you what hp and tq it makes at what RPM - interesting. Anyway 350 cu in, 390 hp and 407 Tq. Pretty sure from memory.
Old Mar 15, 2011 | 07:45 PM
CarGuyOhio's Avatar
CarGuyOhio
It is just a little under 350 CID.... I think 345. Anyone want to confirm? I am lazy tonight. HP/TQ are correct.
Old Mar 15, 2011 | 08:59 PM
Mark Benson's Avatar
Mark Benson
345cid is correct
Old Mar 19, 2011 | 09:40 PM
Patsfan's Avatar
Patsfan
Displacement 5.7 Liters 348 CID
Old Mar 20, 2011 | 08:40 AM
CarGuyOhio's Avatar
CarGuyOhio
Incorrect, the Hemi is 345.
Old Mar 20, 2011 | 09:06 AM
justinryan's Avatar
justinryan
hey guys i have a quick question about the hemi engine......... when driving between 45 to about 70 mph im hearing a weird noise coming from engine when giving light pressure on gas....just wanted to know if you guys have some weird noise too, its done that since i got it so might be normal
Old Mar 20, 2011 | 10:30 AM
Patsfan's Avatar
Patsfan
maybe the MDS is on? What kind of noise?
Old Mar 20, 2011 | 10:35 AM
Patsfan's Avatar
Patsfan
I'm quoting the 09 service manual. So if they changed it in 10, I stand corrected..
"The 5.7L engine (348 CID) eight-cylinder engine is a 90° V-Type lightweight, deep skirt cast iron block, aluminum heads, single cam, overhead valve engine with hydraulic roller tappets. The heads incorporate splayed valves with a hemispherical style combustion chamber and dual spark plugs. The cylinders are numbered from front to rear; 1, 3, 5, 7 on the left bank and 2, 4, 6, 8 on the right bank. The firing order is 1-8-4-3-6-5-7-2."
Old Mar 20, 2011 | 11:17 AM
justinryan's Avatar
justinryan
The noise is hard to explain, kinda sounds like the computer is shorting and when eco light appears the noise seems to go away
