Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
- Dodge Ram 2009-present: How to Install Throttle body
Step by step instructions for the do-it-yourself repairs.
Adding a 90mm throttle body
#21
In defence of RTCarlin... I believe he was comparing a stock engine with a throttle body spacer. A CAI "helps" with increase forced air, a true dual "helps" with less back pressure, a throttle body spacer (by itself) is really no more then an extra extension on your stock intake, with the same ID/OD bolted to you intake manifold.
I don't agree, Every little bit is helps, If bottle necking is really an issue than everyone who installs a CAI, is wasteing there time, and the same to those who install freeflow exhaust systems, being the exhaust alone is not alowing for more air into the engine. Sure it would be nice to go with CAI, larger throttle body, upgraded intake manifold, headers, true dual free flow exhaust.
"...the gains you would see with this mod on an otherwise stock motor would be negligible or non-existent. Unless you plan on upgrading everything else in the airflow department (heads, headers, exhaust, etc) the extra air is gonna be bottle-necked somewhere along the line. "
I should have quoted the post I was referring to. Although, from what I've gathered on the forums, simply adding a CAI and a Catback aren't all that cost effective when it comes down to $$$ per HP. The stock intake in our trucks is relatively efficient. A tuner seems to be the most bang for the buck initially, as it provides the programming needed to reap the benefits of all that extra air. The stock ECM just doesn't have the flexibility to take advantage of it all. Without a tune, the ECM is going to try to compensate for the added air by changing the timing, attempting to keep the motor running at stock specs.
#22
I should have paid closer attention. I totally agree. In fact I think the spacers are a waste no matter what additional mods are put on a truck.
Thanks.. That's what I was getting at.
I was referring to the throttle body / spacer with that comment.
