With 3.92 what RPM with 17" or 20" factory tires @ 65mph
Old Mar 19, 2011 | 01:36 AM
markgpz's Avatar
markgpz
Default With 3.92 what RPM with 17" or 20" factory tires @ 65mph
For those that have the 3.92 gear with the factory 20” or 17” rims/tires I have a question. When the truck is fully warmed up and you’re traveling at an indicated 65 mph on a level road WHAT IS THE RPM OF THE TACHOMETER READING? Please list if you have the 17” or 20” rims. I need to know both. If you have 3.55’s…..please refrain from replying.
Thanks
Old Mar 19, 2011 | 08:32 AM
08DodgeTRX's Avatar
08DodgeTRX
Its the overall tire size and rear gearing thats important not wheel size.
Old Mar 19, 2011 | 02:17 PM
706jim's Avatar
706jim
I was driving yesterday at 60mph. Indicated rpm was about 15-1600. So at 65 you should be seeing about 1650-1700 or so. My truck has the factory 20's and 3.92 gears.
Old Mar 19, 2011 | 03:28 PM
hemirae's Avatar
hemirae
3.92 w/ 20" stock = 1700 @ 65mph
Old Mar 19, 2011 | 04:13 PM
candy08's Avatar
candy08
Abolutely right! Wheel size play no part in this only the tire size.
Old Mar 19, 2011 | 05:59 PM
markgpz's Avatar
markgpz
If you both go back and read my post I stated that I'm interested in the "factory stock wheels and tires" when making this test. I know what the factory tire size is for the 20" and 17" 4th Gen Ram.
The 20" has a diameter of 33" and the 17" has a diameter of 31.7"
Old Mar 19, 2011 | 06:03 PM
Pedro Dog's Avatar
Pedro Dog
the factory 265-70R17 tires are 31.6" tall and the 265-60R20 are 33" tall. With the 31.6" tires, the RPMs are, 3rd gear=2706 RPM, 1st OD=2030 RPM and 2nd OD=1813 RPM. For the 33" tires the RPMs are, 2595, 1947 and 1739 respectively.
Old Mar 19, 2011 | 07:44 PM
markgpz's Avatar
markgpz
Good thinking Pedro Dog. I found a rpm calculator on the web that confirms what you posted.
THANKS!
Old Mar 19, 2011 | 09:16 PM
oldjeep's Avatar
oldjeep
There are 2 different size stock 17" tires. The TRX uses LT275/70R17
Old Mar 20, 2011 | 02:29 PM
candy08's Avatar
candy08
Ouch! Just tryin to help you bud, to my defense it was confusing. Anyhow here's what you need. Ill even through in the OGR.
Find overall gear ratio- (3.92 gears is 2.6264)
OVER DRIVE GEAR x REAR GEAR = OVERALL GEAR RATIO (OGR)
FIND YOUR RPMS at ANY SPEED-
SPEED x OGR x 336 / TIRE HIGHT = RPMs
You can figure it out yourself now
