4x4 service,BAS,ESP and traction light
Old Mar 23, 2011 | 03:15 AM
stmfttr05's Avatar
stmfttr05
Default 4x4 service,BAS,ESP and traction light
i recently had all these lights pop up on my '09 ram hemi,cc,4x4(4x4 service,BAS,ESP and the traction light). is this normal, i dont have any messages on the dashboard, only these lights lit up. i just had my truck lifted 6" and was afraid that something happened to cause this.I did just get a mailer fron the dealership to service my 4x4 for $459, which from what i understand is changing the fluids. the search function didnt help and the manual is worthless. any help is greatly appreciated. Btw i cant shift into 4x4 and my cruise controll doesnt work.
Old Mar 23, 2011 | 04:30 AM
TDTIPMO's Avatar
TDTIPMO
I don't believe that the search function didn't help. There are mulitple threads on this, but I've had this happen to me and all I had to do was take it to the dealer and they reset my 4x4 module. Should be covered under warranty. Hopefully they don't try to dick you since you just put the lift on there. I believe there is a recent PCM flash RRT too, I don't know if you've had that done or not.
Old Mar 24, 2011 | 03:40 PM
FingerBang's Avatar
FingerBang
this has been generally caused due to a wire fault in your speed sensors. there is one at each wheel, if you are able just crawl under and check the wires for a break, you can fix that yourself.
due to your truck just being lifted they more than likely will not cover this under warranty. when you lifted your truck part of the documentation mentioned moving the brackets for them to relieve strain on the wires, if this wasnt done you may have a break in the wires.
