Remote/push button start
Old Mar 24, 2011 | 03:17 AM
shadowsnake6666's Avatar
shadowsnake6666
Default Remote/push button start
I was looking at trying to install the keyless go in my truck and I found this to be a cheaper and better alternative. http://www.auto-innovatio.com/magento/smart-system/dw-tech-st800.html Has anyone seen or heard of this and do you think I can get it to work on my truck?
Old Mar 25, 2011 | 07:26 PM
moosefire66's Avatar
moosefire66
Subscribed
Old Mar 25, 2011 | 08:13 PM
shadowsnake6666
I emailed the guy and he's going to check it out. The keyless go is 700-800 but it looks like people haven't been able to get it to work
Old Mar 25, 2011 | 09:46 PM
lil_jo_25's Avatar
lil_jo_25
Originally Posted by moosefire66
Subscribed
X2! Interesting.
Old Mar 28, 2011 | 01:32 PM
shadowsnake6666
I got the email today looks like it'll work
Hello Robert,
Yes, the St800 will work in your Dodge. We have a system designed to work with the Chrysler 300c Factory Smart key system. This should be the same system that is on your Dodge Ram. Unfortunately we do not have a picture walk through for your vehicle though. A lot of those types of systems either have no steering wheel lock to deal with or the have an electronic steering wheel lock that is unlocked once it recognizes the electric key.The immobilizer in the Dodge is RF based so the bypass that is supplied with he kit will work. You could also go with an xpresskit from DEI for bypassing your immobilizer, if you did not want to use the bypass that is supplied.I have attached the wire diagram for your vehicle so you can see what is required for installing a remote start security system on your Vehicle. Any install shop that can install a remote start vehicle security system should have no trouble installing the ST800.I would first check with some install shops in your area and find one that is able to do this install for you, if you are not comfortable with trying it yourself. Let me know if there is anything else I can do for you.
Thank you, Sean Kirkland U.S. Vice President Auto-Innovatio.com sean@auto-innovatio.com 623-341-7046
2009 Dodge Ram 1500 Remote Start Wiring Guide Vehicle Battery Positive Wire (+): Light Blue/Red (Low current. For high current application go directly to the battery.) Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): Pink/White Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): Pink/Green (There may not be an second ignition wire.)
Vehicle Second Ignition Wire Location: Ignition Switch Harness Vehicle Accessory Wire (+): Violet/Brown (Use 610 ohm resistor for accessory, same wire as starter2.) Vehicle Accessory Wire Location: Ignition Switch Harness
Vehicle Second Accessory Wire (+): Pink/Yellow (This wire will turn on the abs light if not powered up for remote start.) Vehicle Second Accessory Wire Location: Ignition Switch Harness
Automobile Engine Starter Wire (+): Dark Green/Yellow (Not for remote start, use starter2.) Automobile Engine Starter Wire Location: Ignition Switch Harness
Automobile Second Engine Starter Wire (-): Violet/Brown (Use 180 ohm resistor for starter2, same wire as accessory.) Automobile Second Engine Starter Wire Location: Ignition Switch Harness
Factory Anti-Theft System: Daimler Sentry Key Vehicle Immobilizer Factory Anti-Theft System Type: Key Sends a RF Signal to the BCM Module Through an Antenna Located Around the Ignition Cylinder
Crankshaft Sensor Wire: N/A Crankshaft Sensor Wire Location: N/A
Camshaft Sensor Wire: N/A Camshaft Sensor Wire Location: N/A
Car Key Sense Wire (-): Violet/Brown (Use an 8.5k ohm resistor for key sense, same wire as starter 2 and accessory.) Car Key Sense Wire Location: Ignition Switch Harness
Car Neutral Safety Wire (+): N/A Car Neutral Safety Wire Location: N/A
Car Tachometer Wire (-): Tan/Red Car Tachometer Wire Location: At Ignition Coil (On diesel models, the tach wire is at the ECM module on the lower driver side of the engine, pin #24 in front 60-pin plug or at the camshaft position sensor located at the left of the ECM at the 3 pin plug. On SRT-10 models, the tach wire is on the black plug ? pin 18.) Car Speed Sense Wire: Green/Yellow Car Speed Sense Wire Location: Pin #13 in Black Plug at PCM Module (For SRT-10 models, pin 27 in white plug or dark blue/orange wire. In diesel models, pin 11 at the PCM module.)
Car Parking Lights Wire (-): White/Green (Parking lights are negative trigger thru a 1130 or 250 ohm resistor. Must use a relay.) Car Parking Lights Wire Location: At Vehicle Light Switch
Car Brake Lights Wire (+): White/Tan Car Brake Lights Wire Location: At Brake Switch Above the Pedal
Car Reverse Lights Wire (+): White/Light Green Car Reverse Lights Wire Location: In Harness at Reverse Light
Car Horn Wire (-): Green/Violet Car Horn Wire Location: In Harness at Steering Column
Old Mar 28, 2011 | 05:40 PM
SmittySLT's Avatar
SmittySLT
Subscribed also
