Antenna mount removal
Old Mar 31, 2011 | 08:55 AM
10RAMSPORT's Avatar
10RAMSPORT
Default Antenna mount removal
Nevermind, figured it out.
Old Mar 31, 2011 | 05:38 PM
Der Dummkopf's Avatar
Der Dummkopf
I still haven't figured it out.
Old Apr 2, 2011 | 02:01 AM
icemannn's Avatar
icemannn
is there anyway to discard that ugly antenna without lossing radio signal ???
Old Apr 2, 2011 | 02:06 AM
Der Dummkopf
How do you remove the antenna base? Its sun damaged and I need to paint it.
Old Apr 2, 2011 | 09:44 AM
jram99's Avatar
jram99
I removed the one on my old ramcharger. Had to remove the wheel well cover to get to it. It was a pain because the wire was hardwired to the base of the antena mount so I had to disconect it from the radio and fish the wire out from under the dash and through the door opening and out of the truck. Didn't matter though, I was installing a power antena in it's place. Now that was sharp on that ramcharger but it had flat top fenders so was easy to get the base nice and square to the truck. Jeff.
Old Apr 2, 2011 | 11:32 AM
10RAMSPORT's Avatar
10RAMSPORT
Take a flat screw driver and put the head in one of the notches on the chrome nut and tap the end with a hammer...gently...counter clockwise. The nut will unscrew and the black plastic piece will come off. Be careful to hold on to the antenna cable or it will fall into the fender well.
Old Apr 2, 2011 | 05:42 PM
72combo's Avatar
72combo
Will the nut fit over the actual whip on the antenna because if so you can hang on to that and it should hold the antenna base where it belongs.
