Back-up Camera problem?
Old May 6, 2011 | 01:36 PM
Bestbrown2011's Avatar
Bestbrown2011
Just picked up my truck from the dealer. Had the rear-axle recall work done. I gave them a copy of the picture posted here and asked them to check the camera while they had it. They found nothing but sent info to Dodge. Will see how they reply.
Anyone else with this issue? Get it fixed yet?
Old May 6, 2011 | 05:30 PM
redram2008's Avatar
redram2008
are the back up cams color or black/white ?
Old May 7, 2011 | 11:16 AM
Bestbrown2011
They are color. My picture is perfectly clear during the day but I'm picking up some white horizontal lines at night. They float up and down the screen. It looks like some sort of signal interference to me.
Old May 7, 2011 | 06:19 PM
AFF's Avatar
AFF
Have you tried with the lights off?
Old May 7, 2011 | 10:03 PM
Bestbrown2011
Yes, I had the same thought.....maybe signal interference from the lights.
No luck.......same with lights on and off.
Old May 8, 2011 | 05:35 PM
eric2084's Avatar
eric2084
Is there a sunlight sensor on the dash? I've seen some nav systems that automatically switch from daytime to nighttime mode based on that sensor. If the dodge system is the same setup maybe the issue you are seeing is how they are handling that even with the backup camera. You could shine a shining a bright flashlight on it to fool it into thinking it's daytime.
Old May 9, 2011 | 12:22 AM
72combo's Avatar
72combo
After seeing your pictures it made me realize I may have my camera in wrong or there is a slight tilt on the factory camera, I dont see the bumper like you do nor as far back but my driveway is not level so I am going to have to go give it a try somewhere else, If I put the ball in I can see it perfectly fine and well far enough behind but I am thinking maybe I have it in 90 degrees wrong or maybe 180 hmmmmm
Old May 9, 2011 | 09:35 PM
Bestbrown2011
Nice thought and was worth a try. Yes, there's a sensor on the dash but I shined a light on it while dark outside and no change to the picture. It seems like my issue has gotten worse over the past week or so. More white lines and they float up & down quickly. The still photo doesn't do it much justice. I'm going to take a short clip with my HD video camera. Next time I'm at the dealer I'll show it to them.
Old May 10, 2011 | 12:34 AM
eric2084's Avatar
eric2084
Another idea to see if it's related to that sensor would be to cover it up during daylight to fool it into thinking it's dark out.
Old Dec 12, 2011 | 01:49 AM
Shooter840's Avatar
Shooter840
Question What was the diagnosis?
I have the same exact issue described here - I had the dealer just install a OEM backup camera unit and only at night I get the same static/noise on the screen. It goes away if I leave it in reverse for a minute or two, but as soon as I shift out/back into reverse the lines are there.
Has anyone figured this out? Is it a bad camera, or a ground/connection issue?
