Anyone Install Clearance Lights? Where to pull power?
Old May 3, 2011 | 12:20 AM
JC1390's Avatar
JC1390
Default Anyone Install Clearance Lights? Where to pull power?
Like the title says, where did you guys pull power for your clearance lights?
Any info is greatly appreciated!
Thanks!
Old May 3, 2011 | 12:12 PM
TRXHemi's Avatar
TRXHemi
The 3rd gens had the harness in the passenger side A-pillar....it may be the same for the 4th gens.....
Old May 3, 2011 | 09:05 PM
08KK's Avatar
08KK
Here ya go buddy! This is the install sheet for the Ram 2500, use can use the same procedure for the 1500. I have a friend of mine out in AZ. who has installed the lights with out any problems using this sheet.
http://moparestore.trademotion.com/m...s/K6860443.pdf
Old May 4, 2011 | 12:28 AM
JC1390's Avatar
JC1390
AWESOME! Thanks!
Old May 4, 2011 | 09:29 AM
jprovine's Avatar
jprovine
JC - I would check under the right front pillar, by the o S*** handle to see if there is a plug near the bottom. i know if you buy it from dodge you can get the harness for it to plug into that directly. other wise i followed the instructions fro go recon's website on their install, i wish i took pictures of it when i did on my 05, but i didn't. I think it is best if you buy a tube or 2 of rtv sealant, and seal the hell out of it, i never had a leak even in pouring down rain.
that just my 2 cents.
Old May 4, 2011 | 04:49 PM
HammerZ71's Avatar
HammerZ71
I know that's a MOPAR instruction sheet you posted and it shows running to the PDC (fuse box) for power in the '04 & '05 Rams and I know for a fact there is a jack in the passenger pillar for cab lights. Done this install on my truck and a friends' '05.
Pull the pillar and take a peek...
Old May 4, 2011 | 07:10 PM
JC1390's Avatar
JC1390
Gonna pull the pillar in an hour or so...i"ll let you guys know what I find!
Thanks again
Old May 9, 2011 | 02:25 PM
dgriffith's Avatar
dgriffith
i did this install over the weekend, with the mopar lights. went to plug the wire into the T50 pin in harness and there was already a wire in it! any suggestions?
Old May 9, 2011 | 06:45 PM
JC1390's Avatar
JC1390
passenger side "kick panel" down by your feet on the right hand side. Pull the trim off and theres a white plug with (large about 50 wires). theres an orange wire...dont remember what color the tracer is i'll have to look. power comes on with light switch. let me know if ya need more help.
