brake controller
Old Jun 1, 2011 | 12:16 AM
Chuck Nantz's Avatar
Chuck Nantz
Default brake controller
I just bought a new 2011 ram 1500 4x4. hooked up an aftermarket brake controller and it keeps blowing fuses in the fuse box. it does have towing package and factory 7 and 4 trailer plugs on bumper not to sure what to think about it. the controller just came out of my old 2005 truck and worked fine however i do believe that it is the culprit and info is appricated.
Old Jun 1, 2011 | 05:52 PM
oldjeep's Avatar
oldjeep
What kind of controller is it? And do you have the power requirements?
Old Jun 1, 2011 | 10:36 PM
Chuck Nantz
it is a hopkins agility and i checked with the hopkins tech guys and came up with a bad controller. he said to check for voltage being back fed thru the trigger wire coming from the controller and bingo as soon as you call for brake it puts battery voltage thru the "red" wire which is the wire that would get hooked to the cold side of the brake switch
Old Aug 21, 2011 | 03:13 PM
ecman1's Avatar
ecman1
I bought a new Ram 1500 SLT and was told that I could put a factory brake controller into it by plugging it in. I bought the OEM controller and the dealer now says it won't work in the truck. Can anyone help explain this.
Thanks
Old Aug 22, 2011 | 07:21 AM
oldjeep's Avatar
oldjeep
Thanks
Read this
https://dodgeforum.com/forum/4th-gen...10-models.html
