anyone hearing clunks when shifting?
Old Jun 20, 2011 | 04:36 PM
mdram43's Avatar
mdram43
Default anyone hearing clunks when shifting?
my truck recently started making loud clunks when i put it in reverse. well its now making a similar if not the same clunk if I am rolling in traffic and then step on the gas. its an ugly an concerning noise and i've never experience it before. truck has 9,000 miles on it.
Old Jun 20, 2011 | 07:16 PM
oldjeep's Avatar
oldjeep
Might want to crawl under it and rotate the driveshaft back and forth to see how much play is in it. If there is a lot of play then check the pinion nut and see if the pinion seems to be moving fore and aft
Old Jun 20, 2011 | 10:29 PM
atthewmartin114's Avatar
atthewmartin114
you need u joints bud there normally the very back one will have some play up and down when you try and move the shaft. but it needs to be in nutraul
Old Jun 21, 2011 | 12:37 AM
LU229's Avatar
LU229
yup, sounds like u-joints or a pinion nut came loose...better check it out real soon..!
As others said, crawl under and see if you can move the driveshaft while shifter in neutral, make sure you block the wheels or use park brake before you crawl under it.
Old Jun 21, 2011 | 06:38 AM
hounddogg's Avatar
hounddogg
Won' be a u/joint. Either pinion nut or too much clearance between ring and pinion.
Old Jun 21, 2011 | 12:22 PM
atthewmartin114
the truck has very little miles on it. and if he as hounding it like most do. the ujoint is probably got play. im sure that the pinion lash isnt off not from the factory. but if so i would be getting a new truck because that means its going to be a lemon.
Old Jun 21, 2011 | 02:30 PM
hounddogg's Avatar
hounddogg
Are you saying the OP ought to trade trucks? That would cost him thousands of dollars. Its under warranty is it not? Dodge sure isn't going to swap him out for new one with it costing thousand of dollars when its under warranty.
Old Jun 21, 2011 | 05:32 PM
mdram43's Avatar
mdram43
yea trucks new, just bought in december, pretty dissappointing
Old Jun 21, 2011 | 05:39 PM
hounddogg's Avatar
hounddogg
Thats why they give a warranty. I tell you this. Warranty claims on most new vehicles today are a fraction of what they were 20 years back. They are built better and get more miles put on them than ever before. Maybe its nothing hard to find or repair.
