2011 Power Wagon Frame Mounted Nerf Bars ??
Old Jun 24, 2011 | 11:19 PM
aquaholic_'s Avatar
aquaholic_
Default 2011 Power Wagon Frame Mounted Nerf Bars ??
i have a 2011 ram 2500 crew cab power wagon and i'm looking for a set of nerf bars / rock rails / rock sliders whatever you want to call them that mount to the frame and not to the body. if anyone has a pair please list the name of them. every one i find is in some fashion mounted to the body panels under the truck. looking for that nerf bar look that will also help my wife climb up into the truck a little easier.
Old Jun 25, 2011 | 10:36 AM
aquaholic_'s Avatar
aquaholic_
i found these but they do not make make them out of stainless steel. http://www.extremewinchbumpers.com/R...pbarspage.html
Old Jun 25, 2011 | 10:17 PM
sharkhunter10's Avatar
sharkhunter10
Your going to have to custom make some
Old Jun 26, 2011 | 03:00 AM
bremner44's Avatar
bremner44
DeeZee
Old Jun 26, 2011 | 08:14 PM
aquaholic_'s Avatar
aquaholic_
the deezee ones mount to the inner rocker panels and not to the frame.
Old Jun 27, 2011 | 09:51 PM
72combo's Avatar
72combo
If you put the rivnuts in properly it sure does make a difference and they firm up really good, if yours a lose take them back if dealer installed, 3 years warranty, mine one side fell off I blamed someone for it turns out they were not installed correctly, now they are and on the correct side...I thought mine looked different there is a slight bend at the front.
Old Jun 28, 2011 | 03:12 AM
MoparMan1991's Avatar
MoparMan1991
Just get some westin bars, every westin nerf bar is designed to use existing frame holes for easy installation .
Old Jun 28, 2011 | 08:01 AM
bremner44's Avatar
bremner44
I'll have to check mine after work. I'm pretty sure I mounted them to the frame. Only two bolts per bar but it was still a pain to losen and tighten them back up.
Old Jun 29, 2011 | 01:04 AM
72combo's Avatar
72combo
Ya existing holes from 09 and up so far are on the inner rocker panel, none on the frame, the idea is to keep things from hanging down. Have you noticed how hard it is to tell a 4by from a 2wd, same height and everything is nicely tucked up under there.
Old Jun 29, 2011 | 03:36 PM
MoparMan1991
I guess I didn't notice that.
