Advice needed
Old Jul 20, 2011 | 04:39 PM
bosssman's Avatar
bosssman
Default Advice needed
Looking to buy new tires for the truck and came accross a set of rims and tires
Rims are off a 95 Ram
1 - Will these fit my bolt/offset patern ?
2 - will a 12.5 inch wide tire fit without modifications ?
3 - Will a 33inch tire fit without modifications ?
Let me know
Thanks in advance
Old Jul 20, 2011 | 05:02 PM
awful knawful's Avatar
awful knawful
I'm pretty sure the old rams had 16 inch rims. we need at least 17 inchers to clear our brakes.
Old Jul 20, 2011 | 05:05 PM
bosssman's Avatar
bosssman
Sorry forgot to mention they are 18inch rims which will fit just worried about the rest
I'd rather ask than sink 1K in this and them not fit
Old Jul 20, 2011 | 05:42 PM
BigTexMarine's Avatar
BigTexMarine
I think dropping a G on rims and tires from a 95 would be my problem. There is no way they should be anywhere near that much. Shop around, you will find them cheaper!
Old Jul 20, 2011 | 07:49 PM
bosssman's Avatar
bosssman
These are the rims,aftermarket that are on a 95 now
Old Jul 20, 2011 | 08:43 PM
lxman1's Avatar
lxman1
Site Moderator
There are a bunch of those on 3rd gen Rams. They may rub when turning in the front with that deep of a wheel without a lift.
Heck, just have thy guy let you test fit them.
Old Jul 20, 2011 | 11:16 PM
brettj2408's Avatar
brettj2408
bolt pattern is the same so lugs will fit.
you will need to find out if the rims have any kind of offest
33.s will clear just worried about how wide they are if not your turning radius will just decrease a little cause you wont be able to turn your wheel all the way without rubbing
