Spark Plugs
Old Jul 21, 2011 | 04:25 PM
TheRiz's Avatar
TheRiz
Default Spark Plugs
Has anyone tried the E3 plugs on there Dodge Hemis?
Old Jul 22, 2011 | 01:00 AM
hounddogg's Avatar
hounddogg
Do not use. They are a pulse duration plug and cause charge system and running issues. Put out a starnge feedback that bleeds through. G.M. has a tech bulliten out about pulse duration plugs and strange issues.
Old Jul 22, 2011 | 01:14 AM
hounddogg's Avatar
hounddogg
Best deal out there is http://www.amazon.com/Autolite-XP532...2009&carId=001 Download the $2.00 rebate from Autolite. 5 year guarantee on the plugs. Just installed a set couple days ago.
Old Jul 22, 2011 | 02:02 PM
lxman1's Avatar
lxman1
Site Moderator
OEM plugs work just fine.
Old Jul 25, 2011 | 01:57 AM
BOFslime's Avatar
BOFslime
For the hemi - Cheapest I've found for the stock plugs are from dodge-wholesale.com part SPLZFR5C11.
I haven't found the NGK plats (PLZFR5B13EG) designed for this motor sold anywhere yet.
If you have the 4.7, half are copper (above) half are plats, you'll likely have to get them from the dealer. Stay away from the E3's, people have been known to have issues, the hemi's are sometimes very fickle about the plugs used, best to stick with the OE NGK's.
Old Jul 26, 2011 | 07:02 PM
hounddogg's Avatar
hounddogg
The stock does work fine. So does platinum and or long wearing iridium. Benefit is not having to replace for three times longer then inexpensive nickel tipped plug. The Platiumn PLZFR5B13EG plug used in 5.7 Hy-bred is for a while dealer only. At some point it will over the counter. I was going to use them until I did some digging into product and such. I think they were $10 bucks or so each best I recall.
