lifting my truck
Old Jul 31, 2011 | 09:24 PM
timranger1's Avatar
timranger1
Default lifting my truck
I have a 2011 ram 1500 crew cab ,and I would like to do a three inch lift ,to it.is a body lift ok,is there another way to do it ,without doing a really expensive suspension lift.I only want to lift the truck three inches.thanks in advance everyone for your advice...
Old Aug 1, 2011 | 06:49 AM
BULLRAM's Avatar
BULLRAM
That is a quick way that wont affect the ride, there are a few on here and other forums that have a BL, on a 4th gen,
Old Aug 1, 2011 | 08:05 PM
ridem high's Avatar
ridem high
A body lift is what you are looking for.Far more simple,and less expensive than a suspension lift.Check out performance accessories..........
Old Aug 5, 2011 | 01:30 PM
jbgp1200's Avatar
jbgp1200
Hey BULLRAM, been a while since Ive been on here.
He can tell you, I love my PA body lift. Accomplished exactly what I wanted. Low cost, no warranty issues, 35" tires, and the ride with the larger tires is better then stock.
Old Aug 5, 2011 | 01:43 PM
HammerZ71's Avatar
HammerZ71
I've had seven full size, 4x4 trucks in my life and five have been lifted in some fashion. Even though I've got a 4" suspension lift on my 3rd Gen, I've had three trucks with body lifts. I basically did the suspension lift this time because when I did it I was just about to turn 40, I've had back surgery, knee surgeries and shoulder surgery and at this point in my life I wanted to not be bounced around the cab quite so much off-road.
Although it will ride a little harsher off-road and will have a slightly higher center of gravity, there is nothing wrong with going to a body lift or body lift/level combination...
