4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
ok better question where are the holes located under the bed liner?
You can see in this picture where the holes are in relation to the tiedowns. LIke the other guys said, normally in a plastic bedliner there is an oval plug around each tiedown. If you pull that then you should be able to get to the hole.
