Needing new gears and have some questions
Old Aug 19, 2011 | 06:59 PM
337ram's Avatar
337ram
Default Needing new gears and have some questions
Ok just a couple ???s , I have 2009 dodge 1500 4x4 4.7 with 35s, i am wanting to go to 4.56 gears, my 1st? is where is the best place to buy them, please provide link. 2nd Can I install the rears 1st , IF I do not use 4x4 until I save more $$$ to do the fronts. I am in need of some umph back, I pull a 20ft trailer and my baby has no **** lol
Old Aug 19, 2011 | 08:15 PM
lxman1's Avatar
lxman1
Site Moderator
1 Might try reading thru here https://dodgeforum.com/forum/3rd-gen...528-gears.html
2 Yes you can, but it is risky if the transfer case accidentally got engaged, kaboom!!
Old Aug 19, 2011 | 09:30 PM
BigTexMarine's Avatar
BigTexMarine
This isn't exactly a mod you want to half-***. If you do it, you want to do it all the way to get everything knocked out at once and reduce your chance of problems. But it is definitely a mod worth getting and worth the money. Huge difference in mine since I did the swap. Shop around for prices and brands though.
Old Aug 19, 2011 | 09:59 PM
337ram's Avatar
337ram
Tex what did you pay for everything parts labor etc
Old Aug 20, 2011 | 11:45 AM
BigTexMarine
For my 2 sets of gears, install kit, and labor, about $1600.
Old Aug 20, 2011 | 12:08 PM
jason2922's Avatar
jason2922
2 sets of gears with rear DTT LSD $2300.
Old Aug 20, 2011 | 12:54 PM
HammerZ71's Avatar
HammerZ71
Technically, you can change just the rear gears IF you never put it in 4 wheel drive, but if you do, the flatbed guy will be going back to pick up your transfer case and probably both drive shafts off the side of the road after he winches your truck on board.
Personally, I'd save up and have both done. Going rate for gears, install kit an labor should range you anywhere from about $1250-$1600 depending on your area and where you go. Add a good LSD (Auburn or DTT) and you can add about $500-$600...
4.56s will help considerably given the fact you run 35s on a 4.7 V8, towing performance should improve dramatically...
