4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Got the gears swapped a little bit ago, the back are broke in fine. They served their time. How do you really break in the front though, just run around in 4wd for a while everywhere you go?
I wouldn't run around on the street in 4 wheel, that will cause things to bind up alot (especially on corners), if you want to drive around on dirt/gravel roads or do some light wheeling that's what I would do. JMHO
Google earth where you live and I bet you can find some kind of dirt or gravel roads closer than you think. If not, might try running it in the rain or wait until it snows!
I run mine on the freeway on long runs, obviously with no hard turns. Enough for them to get hot for break-in and then disengage. I've done that with all my 4x4s and never had any issues.
