Power door lock
Old Aug 30, 2011 | 11:35 AM
joker055's Avatar
joker055
Default Power door lock
Anybody have a power door lock fail? I'm at 38000 miles, and the rear passenger door won't lock or unlock when using the remote or lock button.
Dealer wants $200 for the part, Advance can't order it. Guess I'll give it a try myself
Old Aug 30, 2011 | 01:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
i had one fail in mine. In my case it was the latch assembly itself that failed and i replaced it for about 35 bux. But others have found broken or pinched wires in the rubber boot between the door and body. So check their first.
also check here
http://www.dodge-auto-parts-dealer.com/parts.htm
choose yr,mk,mo and then front door and then latch. I see them for about 62 bux
Old Aug 30, 2011 | 04:58 PM
jawsdc's Avatar
jawsdc
had an actuator replaced at 35K (front passenger door). mine was a little "lazy" for a few weeks, i had to press the remote several times (or the unlock button on the truck). it eventually stopped working all together.
the repair is not that difficult, i can send you a diagram if you need it.
Old Sep 5, 2011 | 10:32 AM
joker055's Avatar
joker055
please send, that would be great!
Old Sep 5, 2011 | 10:25 PM
Zookeeper's Avatar
Zookeeper
I had the same exact thing on mine at 30,000; right rear door. They replaced it under warranty. Took them about 45 minutes.
Old Sep 5, 2011 | 11:13 PM
Mikeyyy816's Avatar
Mikeyyy816
also check here
Thanks for the site, I'm sure I'll be using that someday...
Old Sep 6, 2011 | 12:31 AM
brettj2408's Avatar
brettj2408
What you got for year. I think it was 2010 with an L03 recall with latch actuator assemblies for passenger front and rear
