Aircon Vapour
Hi I was alarmed to see a large amount of vapour appear from between the steering column.
I noticed that it was without scent so that ruled out smoke, I tested to see what it was. I eventually found that it was because I kept turning the aircon off and on every 5 mins or so.
Does anyone think this could be a problem?
Moisture. water on evaporator coils and such. If it was freon your ac would not be working. Depends on humidity and such. Why were you turning ac on and off every few minutes? Thatt can't be good for the ac system.
I know it wasn't good for the unit and haven't done it before, I'd done it around 6 times, it was because we'd just had a storm and it was too cold for Aircon on but too hot to put the blower on the screen so it was aircon on for 5 off for 5, I won't be doing it again let me tell you.
