Code PO 456
Old Oct 3, 2011 | 05:02 PM
TheRiz's Avatar
TheRiz
Default Code PO 456
Check engine light came on this morning.Now home from work, used codereader,PO 456 came up, small evap system leak. Where do I start to look for this?
Old Oct 3, 2011 | 06:05 PM
lxman1's Avatar
lxman1
Site Moderator
Loose or bad gas cap. That's where I would start.
Old Oct 3, 2011 | 06:20 PM
HammerZ71's Avatar
HammerZ71
Yep, most common cause is the gas cap, from there look around the evap canister for a failed hose clamp. I dunno if they use any better on the 4th Gens, but the hose clamps on the 3rd Gens are the cheesiest I've ever seen. I'll invest $2 in a clamp anytime I happen to be working around one and just go ahead and replace it with a better quality clamp even if the thing still looks ok...
Old Oct 3, 2011 | 07:01 PM
TheRiz's Avatar
TheRiz
Default Code 456
I will check it out, see what happens.
