Fan on at startup
Old Oct 13, 2011 | 03:21 PM
WaySlowWhitey's Avatar
WaySlowWhitey
Default Fan on at startup
Recently when I start my truck ('11 1500 4x4 HEMI) after it's sat in the garage all night, the fan kicks on. Not the interior a/c or heater fan but the cooling fan. When I asked my Service Mgr. he said that was normal. I find that hard to believe as I thought the fan was driven off the thermostat and kicked in accordingly. Am I missing something?
Old Oct 13, 2011 | 04:02 PM
ridem high's Avatar
ridem high
I have noticed that sometimes.Are you shutting your truck off while the engine fan is still running?I have been letting my fan kick off before shutting the truck down here lately,and haven't noticed the fan turning on at start-up.Maybe the computer is storing the info of the fan being on when you turn your truck off,and turns the fan back on when you start it.IDK.....
Old Oct 13, 2011 | 04:10 PM
WaySlowWhitey
No, I haven't. I'm hoping that isn't something that I need to begin doing.
Old Oct 13, 2011 | 04:14 PM
Nate769's Avatar
Nate769
Mine does it almost every time, No Joke. I don't know what causes it, my fan is not on when I shut the truck down either. I don't know whether they have linked it with the cooling system or what but it might be nice to know too.
Old Oct 13, 2011 | 04:19 PM
WaySlowWhitey
Dodge said it's normal but also said that my idle dropping under 500 then climbing back up to normal when i come to a stop (Still in Drive, not parking) is as designed.
Old Oct 13, 2011 | 04:23 PM
ridem high's Avatar
ridem high
I have also noticed that,I was told the same thing!
Old Oct 13, 2011 | 05:28 PM
plumcrazy73's Avatar
plumcrazy73
electric fans come on with the ac if I am not mistaken
Old Oct 13, 2011 | 07:32 PM
AZdave's Avatar
AZdave
Is your HVAC vent selector set to Defrost? It'll run the A/C compressor - and the condensor fan.
Old Oct 13, 2011 | 09:17 PM
lxman1's Avatar
lxman1
Site Moderator
The clutch fluid when cold settles in the bottom of the clutch causing it to be tight when started cold. After a minute or two, the fluid disperses and the clutch releases as designed until there is enough heat drawn across the clutch from a hot radiator for the fluid to do it's thing and tighten up the clutch as needed to speed up the blades for more cooling.
Old Oct 14, 2011 | 08:59 AM
WaySlowWhitey
The a/c and heater is off, the vehicle has been sitting in a garage for 8-10 hours thus no temp in the motor. I don't think the fan should run right at start. I can understand it running after the motor has been running and built up some temp but otherwise it shouldn't be on at startup. It runs as though the truck has been in stop-and-go traffic for a while.
