REN mygig bluetooth out after ios 5 update
Old Nov 2, 2011 | 04:06 PM
xsdbs's Avatar
xsdbs
can you press the VR button and say "transfer call"? What does Uconnect say when you try this?
Originally Posted by jawsdc
Anyone have issues with iphone compatibility after update to IOS 5? no phone volume over stereo but uconnect detects the call. i have tried deleting the phone and re-pairing to no avail.
i also no longer have the button on the phone to toggle between uconnect and iphone input.
everything was working perfect before the update.
iphone 4
ios 5
REN
MyGig OS 9.292
2009 Dodge Ram 1500
any suggestions would be appreciated!!
Old Nov 2, 2011 | 04:39 PM
jawsdc's Avatar
jawsdc
thanks for the help. the first post you responded to was from another person. mine does not work at all, in park or out.
when i attempt to make a call and press the VR button then say transfer call, the response is "transferred call to uconnect".
no bluetooth volume over the stereo though. it appears that it does not make any difference after trying to transfer.
i do not have the option to transfer call on the iphone screen as i did before the update.
Old Nov 3, 2011 | 10:39 AM
xsdbs's Avatar
xsdbs
I apologize if I missed this, what phone do you have? Did you try to reset the phone by holding the power button on top while pressing the round "wake" button on the face of the phone until the Apple appears, then release the buttons. I have seen these phones act weird and perform this reset and the phone works correctly. (It's worth the try and it won't damage anything)
Old Nov 3, 2011 | 11:31 AM
jawsdc's Avatar
jawsdc
iphone 4
ios 5
REN
MyGig OS 9.292
2009 Dodge Ram 1500
No luck with the hard reset
No luck deleting phone from uconnect
No luck deleting uconnect from phone
No luck doing both together
Old Nov 3, 2011 | 12:42 PM
xsdbs's Avatar
xsdbs
ok, I got 1 more thing to try, press the uconnect button and say "setup, reset" you should be asked if you're sure you want to reset the Uconnect, say "yes". You will then be told that this will remove all phone pairing etc and asked if you want to proceed, say "yes". Then remove Uconnect from the devices list. Start a new pairing of the phone & uconnect. let me know if this helps.
iphone 4
ios 5
REN
MyGig OS 9.292
2009 Dodge Ram 1500
Old Nov 3, 2011 | 05:37 PM
jawsdc's Avatar
jawsdc
i noticed today that my iphone had gotten a new update (it rearranged my apps a little). as soon as i got in my truck at lunch someone called and it went straight to bluetooth! all functions are back to normal.
thanks for all the suggestions, as it turns out i just needed a little patience.
Old Nov 4, 2011 | 12:37 PM
xsdbs's Avatar
xsdbs
Was this an over the air update? Can you look in the settings menu, about phone, is the version still 5.0? (9A334) Thanks for the information.
Old Nov 7, 2011 | 10:13 AM
jawsdc's Avatar
jawsdc
yes, it was an update via icloud/wifi but it still shows 9A334 as the software package.
thanks again xsdbs
Old Nov 8, 2011 | 12:18 PM
xsdbs's Avatar
xsdbs
Well, out of curiosity about this update, I emailed an Apple contact that I have and asked about this update.. He says that there hasn't been an update made yet for the iOS 5.0. There is a beta update that is being tested by developers only. This is an update (5.0.1) for the battery life glitches. He's thinking that your update may not have been complete and some how was completed thru WI-fi (?).
I know it doesn't matter because it's working but I thought I would mention that there wasn't an update. (yet) He also said that updates changes the SW version # (9A334...).
thanks again xsdbs
Old Nov 8, 2011 | 12:22 PM
jawsdc's Avatar
jawsdc
that makes sense, i was still seeing a blue bar on the bottom of the newsstand app after i updated via computer; then a week later the app goes clean and my bluetooth works.
