Q about the Bully Dog
Old Nov 28, 2011 | 04:17 AM
Darek117's Avatar
Darek117
Default Q about the Bully Dog
I ordered a Bully Dog Triple GT tuner and I read some where that it needs a fuse or some crap. I only saw this at one site in a review is this true or will it just plug and play on my 4th gen Ram 1500?
Old Nov 28, 2011 | 08:26 AM
Nate769's Avatar
Nate769
It should come with its own OBD2 adapter, and with that should be its power wire, and in that power wire is a fuse. You can plug it in and switch it over to use the power from the obd2, but personally I would rather it have its own power source. Up to you, you just don't know about surges with these new computer systems.
Old Nov 28, 2011 | 09:04 PM
Mikeyyy816's Avatar
Mikeyyy816
Old Jul 4, 2014 | 04:59 PM
bluebeast1562's Avatar
bluebeast1562
Regarding the above mention question, I just did the install to the power block/fuse box under the hood. Ran the power wire to the USB interface 10 amp fuse in order have the unit turn on/off with key. Seems to work without issues (drive way test/run) any issues with the way it is ran? Tried to ensure that the used fuse would not have issue with other systems.
Thanks
