New 1500 Sport QC Owner. True Blue Pearl
Old Dec 15, 2011 | 12:09 PM
Rated R's Avatar
Rated R
All they've said is that its $170 installed and it the same as the factory one.
Old Dec 15, 2011 | 12:29 PM
Pedro Dog's Avatar
Pedro Dog
You are getting the lower rated set up, this setup is good enough for the capacity of the truck as long as you use a WDH which I highly recommend. The full on hitch that does not come standard and requires removing the factory installed cross member can be a class IV or class V. These hitches give you a lot more capacity without the WDH. You would need one of these if your trailer is not capable of having a WDH used on it like some boat trailers.
Old Dec 15, 2011 | 12:47 PM
Rated R's Avatar
Rated R
I suspected as such because of the price. I may pay the difference for the higher spec and just have them issue me an IOU.
Old Dec 15, 2011 | 02:15 PM
Rated R's Avatar
Rated R
The dealer that my dealer was going to do the trade with sold the truck to another dealer so all of this was for not. Guess I'll be ordering one now as they're nowhere to be found at dealers in the NW.
Old Dec 15, 2011 | 03:27 PM
frogslinger's Avatar
frogslinger
The hitch I got mounts under the factory crossmemeber on its own cross member... the hitch is rated for substantially more than the truck. Here is the install sheet:
http://sitepro12.sitepro.com/masterl..._14374_INS.pdf
There is an even higher load version:
http://sitepro12.sitepro.com/masterl..._15572_INS.pdf
Old Dec 16, 2011 | 12:11 AM
LU229's Avatar
LU229
When you order your new SPORT truck, order the factory hitch, its more hitch than you`ll ever need on a 1/2 ton truck.
Also, order the "remote start" factory installed, you`ll be glad you did.
Old Dec 16, 2011 | 12:45 AM
frogslinger
I respectfully disagree with the first part... the oe hitch is a joke. I fully support that second part of the statement.
Old Dec 16, 2011 | 10:10 AM
LU229's Avatar
LU229
No problem with you disagreeing, as a matter of fact, i`m glad you DO disagree, because now you can open up on some facts about this. Personally, i myself, would like to know why you would say that the factory "frame mounted" hitch is a joke. It will more than stand up to anything that these 1/2 ton trucks will ever tow. If the factory installed reciever hitch wasnt up to the job intended, then i dont believe dodge would be installing it. If a person was towing more than its rated for, then expect failure. The hitch i would worry about, is the picture in here of that bumper mounted bolt-on.
re: Remote start, best thing since sliced bread for sure...lol.
Since ordering mine factory installed, i`d never buy another vehicle without it.
Old Dec 16, 2011 | 10:21 AM
oldjeep's Avatar
oldjeep
Depends on which OE hitch you are talking about - there are 2 options. There is the little receiver piece that basically just bolts under the bumper and ties into the fraame crossmember and there is the factory class 4 which is a full on receiver hitch.
I've got the full on factory class 4 and its as beefy as any other receiver I;ve seen
Old Dec 16, 2011 | 01:22 PM
frogslinger
IIRC (I am currently on the Iraq/Kuwait border and so cannot crawl under my truck) the max rating on the factory hitch is either 5 or 6K (for the "class iv"). Most of the trucks are rated to between 6.5k and 10.5k so the hitch is way under the trucks capacity. Class IV is a size rating not a capacity rating. (Former hitch specialist for uHaul).
