What are you guys using for spark plugs?
Old Jan 24, 2012 | 08:39 PM
  #21
hounddogg's Avatar
hounddogg
Not worried about OUR cost but their cost when looking at profits when assembling and to keep the MSRP down.
Old Jan 25, 2012 | 06:09 AM
  #22
hounddogg's Avatar
hounddogg
Another thing. The debate over copper and platinum,iridium. the COPPER is the center core. Not the electrode. The standard copper CORE plug has a cheap,base electrode. The platinum's have a COPPER core with a platinum electrode. same with Iridium. Its the electrode that is longer wearing due to metals that withstand the spark better. The Autolites I used are a COPPER CORE like the factory plugs with a Iridium electrode. I have also owned several vehicles with 100,000 life spark plugs. I've never had a seize issue. I'm sure it happens. I don't think its too common. There being changed by the 1000s daily I bet.
Old Jan 26, 2012 | 07:36 PM
  #23
Dusty48's Avatar
Dusty48
Now when I say "seized," I mean the threads are destroyed upon removal of the spark plug (threads pull out of the casting).
Late vintage Ford Triton motors are famous for it. You'll see this ocasionaly on GM V-6s, Toyota inline 4s, Hyundais, and Saturns. In cars other than Ford trucks, I've personnaly witnessed 8 or so over the last five years. Saw one 2.0 Mopar as well.
Regards,
Dusty
2010 Ram Big Horn 1500 Quad Cab 2WD, 5.7 Hemi, 545RFE, 3.92 LSD, dual exhaust, 20” wheels
Old Feb 7, 2012 | 04:56 PM
  #24
moparfreak77's Avatar
moparfreak77
Been doin some research...If you go on Rockauto.com, they list a Autolite XP5325 for an 09 Ram hemi. A 04 Nissan 350Z uses the same plug, only the plug options for the Nissan are far greater. Does it stand to reason any plug for that Nissan would workin our Rams? thanks
Old Feb 10, 2012 | 08:51 AM
  #25
moparfreak77
Opinions please!
Old Feb 10, 2012 | 09:01 AM
  #26
hounddogg's Avatar
hounddogg
Use the plug that is called for. I used the XP5325s. I have about 4000 miles on them. Runs good,fuel mileage good,idle is smooth.
Old Feb 10, 2012 | 02:10 PM
  #27
dirtydog's Avatar
dirtydog
Moderate User
I would not stress that a plug you buy can fit a Nissan as well as your Ram. This is normal.
Plugs are pretty standard acorss the board and can fit many different engine platforms. The thread pitch/taper, the depth it goes into the cylinder head, and the heat range are all that need to match for cross-over applications. Generally the Gap is preset to larger dispalcement engine's as V8's but is always a good idea to check for proper gap because of this. Also, because not all lerger diplacements have the same reccomended plug gaps.
Old Feb 10, 2012 | 05:26 PM
  #28
hounddogg's Avatar
hounddogg
I think what the question is that the Nissan shows many suitble plugs. Does this mean that they will also work in a Hemi. If thats the question . Maybe. Chart shows the XP5325s. Not others like the Nissan does. Why do you want to know?
Old Feb 10, 2012 | 05:33 PM
  #29
dirtydog's Avatar
dirtydog
Moderate User
Yes. I've already answered this and explained in my post above.
I'me sure he wants to make sure plugs listed for a Nissan aren't strictly for a Nissan. One set of plugs can potentially be installed into 20 different style cars if they utilize the same requirements.
Old Feb 11, 2012 | 08:32 AM
  #30
moparfreak77
I dont care about the same plug fitting, I realize that dont matter. We have 9 spark plugs listed for the Ram, 16 for the Nissan. I am interested in the Bosch plugs as there is a $3-$4 a plug rebate, brings the plugs down to $1 or $2.
