airbags on lift 4inch lifted 4x4
Old Feb 12, 2012 | 10:05 PM
rolltidehemi's Avatar
rolltidehemi
Default airbags on lift 4inch lifted 4x4
Want to put bags on my lifted truck have the spacers in the back so I am figuring that the regular airbags will work, the truck looks like the front is higher due to the way the hood is higher than the back, level reveals truck is level but want to put the bag in for when I tow my boat and to see if the bag may push the back up a little for aesthetics, so will the regular bags work, I am figuring they will since coils are the same.
Old Feb 13, 2012 | 06:48 AM
HammerZ71's Avatar
HammerZ71
I would imagine they'd work fine, but you may want to call/email the bag manufacturer before spending the money.
I had to look into it when I bagged my truck (4" lift as well) and found at that time that only the Air Lift Ride Control bags would work without modification due to the way they mounted. Obviously different animal since I have rear leafs...
Old Feb 13, 2012 | 07:23 AM
iskybantilus's Avatar
iskybantilus
so long as the rear coil spacers have a hole through the middle they should work. The air hose comes out the top of the airbag and goes through the top of the spring and spring mount.
i have top gunz rear coil spacers ... and they specifically tell you that they were designed to work with the airbags.
Old Feb 15, 2012 | 03:01 PM
rolltidehemi
guess I'll have move the center bolt and put three bolts in a triangle pattern to hold spacer in place
