2009 dodge ram 4x4 hemi Automatic transmision SWEATING
Old Feb 23, 2012 | 04:31 PM
darin89's Avatar
darin89
Default 2009 dodge ram 4x4 hemi Automatic transmision SWEATING
I am wondering if any other owners have taking thier truck to the dealer for warranty work and mention that the truck farted as my friend describe when going up hill becuase i can figure is it bogged then took off . he noticed his transmission looked wet and when the technician looked at they said it is okay transmission just sweating.
Old Feb 23, 2012 | 04:50 PM
oldjeep's Avatar
oldjeep
Transmissions get warm, makes sense that you would get condensation on it.
Old Feb 23, 2012 | 05:35 PM
darin89's Avatar
darin89
but sweating out transmission fluid. i understand the condesation angle but actual transmission fluid
Old Feb 23, 2012 | 05:46 PM
oldjeep's Avatar
oldjeep
Ah. Definitly shouldn't be sweating (leaking) trans fluid
Old Feb 23, 2012 | 07:50 PM
Pedro Dog's Avatar
Pedro Dog
https://dodgeforum.com/forum/4th-gen...and-trans.html
Maybe they said seeping not sweating? I had a pan leak and the dealer said that seepage is OK. I argued and they ended up putting on a new pan gasket and replaced 7 quarts of trans fluid under warranty.
Another possibility is that the trans fluid got so hot that it boiled out of the filler tube and got on the transmission. I've never heard of this on Rams but chevys used to do it.
If the transmission is actually sweating through the casting, then it's a defective cast and they are trying to avoid the repair.
Old Feb 24, 2012 | 08:53 AM
WNDERR's Avatar
WNDERR
No way a transmission should "sweat." Condensation occurs on a COLD object, when the warmer, moister, air comes in contact with it.....
Old Feb 24, 2012 | 12:14 PM
DodgeCares's Avatar
DodgeCares
Darin,
There should not be transmission fluid coming out of the transmission and by no means is that normal. I would recommend another dealer if there was trans fluid on the outside of the transmission and the dealer indicated that was normal.
