5.7 4x4 trans oil change - help
Old Mar 9, 2012 | 08:39 PM
Sweller3's Avatar
Sweller3
Default 5.7 4x4 trans oil change - help
Hi,
I just changed transmission oil (pan drop with filters) and I first added around 6L of atf+4, but then I checked level and it seemed to low, so I added around 0.5L more and level chenged very little, for about 2mm... So at 105°F there should be around 35mm above dipstick, and I have only around 24mm to 26mm. Is it possible that EVIC reads to high temperature? I drove with truck and it seems all oky...
I'm just scared I added a little too much oil... :S
Any help would be apricciated
Thank you!
Regards,
Rok
Old Mar 9, 2012 | 08:43 PM
Sweller3's Avatar
Sweller3
Oh, and outside temperature is around 28°F so it0s a bit cold... :P
Old Mar 10, 2012 | 12:10 PM
LU229's Avatar
LU229
Go by whatever the dipstick reading is when trans temp is full operating temp, you`ll be ok
Old Mar 11, 2012 | 07:50 PM
HEMICOWBOY's Avatar
HEMICOWBOY
The owners manual says to check it at normal operating temperature 180 degrees. The highest I've seen mind is 178 while pulling my boat with outside temperature at 104.
Old Mar 12, 2012 | 07:16 AM
Sweller3's Avatar
Sweller3
That's right, on normal driving I get around 140°F. Basically it really doesn't matter if I added little bit too much oil, because it never rises so high...
But I will check and remove excessive oil in summer anyway, so I could sleep tight
Oh, I got little over 200°F when I was pulling chapparal 270 on highway when I was pulling full throttle uphilll (German highyway is not as flat as they tell you on DiscoveryChannel )... that was the highest. And I won't do the same again, I think
