Tranny Service-How much Fluid?
Old Mar 15, 2012 | 03:10 PM
dewright's Avatar
dewright
Default Tranny Service-How much Fluid?
I want to drop my transmission pan to change my filters and fluid for my 2010 Ram 4x4, any body know what my refill capacity will be? Thanks
Old Mar 15, 2012 | 09:03 PM
Pedro Dog's Avatar
Pedro Dog
from the 2009 manual
TRANSMISSION FILL
To avoid overfilling transmission after a fluid change or overhaul, perform the following procedure:
1. Remove dipstick and insert clean funnel in transmission fill tube. 2. Add following initial quantity of Mopar® ATF +4 to transmission: a. If only fluid and filter were changed, add 10 pints (5 quarts) of ATF +4 to transmission. b. If transmission was completely overhauled and the torque converter was replaced or drained, add 24 pints (12 quarts) of ATF +4 to transmission. 3. Check the transmission fluid (Refer to 21 - Transmission and Transfer Case/Automatic - 45RFE/545RFE/FLUID and FILTER - Standard Procedure) and adjust as required.
Old Mar 15, 2012 | 09:07 PM
Pedro Dog's Avatar
Pedro Dog
FLUID AND FILTER REPLACEMENT
For proper service intervals (Refer to 04 - Vehicle Quick Reference/Maintenance Schedules - Description) .
REMOVAL
1. Hoist and support vehicle on safety stands. 2. Place a large diameter shallow drain pan beneath the transmission pan. 3. Remove bolts holding front and sides of pan to transmission. 4. Loosen bolts holding rear of pan to transmission. 5. Slowly separate front of pan away from transmission allowing the fluid to drain into drain pan. 6. Hold up pan and remove remaining bolts holding pan to transmission. 7. While holding pan level, lower pan away from transmission. 8. Pour remaining fluid in pan into drain pan.
Transmission Filters - 4X4 Shown
1 - PRIMARY OIL FILTER 2 - COOLER RETURN FILTER 3 - COOLER RETURN FILTER BYPASS VALVE 4 - VALVE BODY
9. Remove the screw holding the primary oil filter (1) to valve body. 10. Separate filter from valve body and oil pump and pour fluid in filter into drain pan. 11. Inspect the oil filter seal in the bottom of the oil pump. If the seal is not installed completely in the oil pump, or is otherwise damaged, then remove and discard the oil filter seal from the bottom of the oil pump. If the seal is installed correctly and is in good condition, it can be reused. 12. If replacing the cooler return filter (2), use Oil Filter Wrench 8321 to remove the filter from the transmission. 13. Dispose of used trans fluid and filter(s) properly.
INSPECTION
Inspect bottom of pan and magnet for excessive amounts of metal. A light coating of clutch material on the bottom of the pan does not indicate a problem unless accompanied by a slipping condition or shift lag. If fluid and pan are contaminated with excessive amounts of debris, refer to (Refer to 21 - Transmission and Transfer Case/Automatic - 45RFE/545RFE - Diagnosis and Testing)
CLEANING
1. Using a suitable solvent, clean pan and magnet. 2. Using a suitable gasket scraper, clean original sealing material from surface of transmission case and the transmission pan.
INSTALLATION
CAUTION: The primary oil filter seal MUST be fully installed flush against the oil pump body. DO NOT install the seal onto the filter neck and attempt to install the filter and seal as an assembly. Damage to the transmission will result. 1. If necessary, install a new primary oil filter seal in the oil pump inlet bore. Seat the seal in the bore with Installer 6960-A or another suitable tool (appropriately sized drift or socket, the butt end of a hammer etc.). 2. Place replacement filter in position on valve body and into the oil pump. 3. Install screw to hold the primary oil filter (1) to valve body. Tighten screw to 4.5 N·m (40 in. lbs.) torque. 4. Install new cooler return filter (2) onto the transmission, if necessary. Torque the filter to 9.5 N·m (84 in.lbs.). 5. Place bead of Mopar® RTV sealant onto the transmission case sealing surface. 6. Place pan in position on transmission. 7. Install bolts to hold pan to transmission. Tighten bolts to 12 N·m (105 in. lbs.) torque. 8. Lower vehicle and fill transmission with MOPAR® ATF +4.
Old Mar 16, 2012 | 12:02 AM
LU229's Avatar
LU229
Pedro, dammm dude, nice job..! This should be a sticky...! Rep`s for you bro.
Old Mar 16, 2012 | 10:04 AM
DodgeCares's Avatar
DodgeCares
Dewright,
Pedro nailed it.
Old Mar 16, 2012 | 10:28 AM
dewright's Avatar
dewright
Thanks guys for the info!
