rear seal leaking at 57k miles
Old Mar 19, 2012 | 11:21 PM
kddsRam's Avatar
kddsRam
Default rear seal leaking at 57k miles
got home from work and smelled burning oil, crawled under truck and found gear oil sprayed all over back of fuel tank. Damn pinion seal already. I had the transfer case seal replaced at 30k miles as well when I noticed it leaking out the boot while changing the oil. I need to find the fill hole to top off fluid asap though because it looks like a lot of oil sprayed.
Old Mar 19, 2012 | 11:59 PM
LU229's Avatar
LU229
Another 4th gen dodge truck owner let down, what a surprise...NOT...! Sure glad mine is gonna be going bye bye very soon. I`ve never had a vehicle with as many issues as BOTH of my 2010 4th gen trucks have had.
Old Mar 20, 2012 | 07:41 AM
2011BlackRam's Avatar
2011BlackRam
Did you get the rear diff recall performed when it came out? Maybe the pinion bearings have a little excess wear due to the lack of diff fluid from the factory, causing the seal to leak.
Old Mar 20, 2012 | 08:28 AM
oldjeep's Avatar
oldjeep
There was no recall for the 2009s - that was a 2010 problem
Old Mar 20, 2012 | 08:29 AM
oldjeep's Avatar
oldjeep
For the OP - when was the last time you replaced the diff fluid and are you sure it was the right kind? Its really easy to cook the oil out of a diff if it is the wrong type or the level is low.
Old Mar 20, 2012 | 01:07 PM
kddsRam's Avatar
kddsRam
at 30k. Was done at different dealer, I could only assume but they were using bulk QS lubricants so who knows, at least it was done at a dealer and there is record of it if it is f'ed up. That may explain it since I do not see too many posts anywhere of this happening. Should be covered under powertrain warranty. Coincidentally, I have noticed a bit of noise with highspeed coasting, not sure if all related here but will get the fluid changed again, dropping off tomorrow and got a loaner vehicle to get to work. These guys do not use QS products.
Old Mar 20, 2012 | 02:05 PM
oldjeep's Avatar
oldjeep
Should be covered by the powertrain warranty. Noise while coasting could certainly be a bad pinion bearing if it was running dry.
No idea what a QS product is, but I put Valvoline in mine the time I changed it and the dealer puts whatever they put in it. I'm at around 61K on mine
Old Mar 20, 2012 | 05:16 PM
jawsdc's Avatar
jawsdc
Quaker State - most people here don't seem to have a very high opinion their products
Old Mar 20, 2012 | 05:27 PM
huntergreen's Avatar
huntergreen
this a pia for sure, might try a different dealer.
Old Mar 20, 2012 | 11:45 PM
LU229's Avatar
LU229
...and with dam good reason i might add. Valvoline is the best bang for the buck.
