pop noise...i need help.
Old Mar 21, 2012 | 09:00 PM
dperkins's Avatar
dperkins
Default pop noise...i need help.
I just starting hearing a pop sound from the right front of my 2012 1500 4x4. i get this sound when the body shifts to the right, it is driving me crazy. i love my new truck but this has to be fixed. i would just take it to the dealer, but the will say it is from the leveling kit i installed. it is not. it started about 600 miles after i leveled it. thanks in advance for any help.
Old Mar 22, 2012 | 12:14 AM
LU229's Avatar
LU229
The spring may not be seated correctly. Check the ball joints and tie-rod ends.
Go back over any nut or bolt that you removed while installing your lift kit.
You dont know for sure yet that it ISNT the leveling kit until you check it.
Old Mar 22, 2012 | 07:20 AM
dperkins's Avatar
dperkins
Default pop noise..
last week i removed the kit and put everything back to stock. i even looked up all the specs for the bolts. noise was still there, i reinstalled the kit. so i know its not the kit. since my first posting i have chased the noise to the right front body mount. going to check all the bolts today.
Old Mar 22, 2012 | 08:56 AM
RAMULAK's Avatar
RAMULAK
Check that top of the shock is in tight. I had that same issue in an SUV and it was the strut top was loose and moving around. Just a thought.
Old Mar 22, 2012 | 11:33 AM
jnram's Avatar
jnram
If it's still there when you pulled the kit, pull 'er again, and take in to the dealer.
Sounds like something isn't seated right though... shocks/springs/some bolt/etc.
I know it's a pain, but if it's there with the kit off, take it in that way.
Old Mar 22, 2012 | 11:36 AM
LU229's Avatar
LU229
I think member "Mikeyyy" had problems with cab mounts in the past if i remember correctly.
Do a search for 4th gen cab mounts, you might find his post on it.
Old Mar 22, 2012 | 07:40 PM
ridem high's Avatar
ridem high
I had a popping noise,turned out to be the rack and pinion.Actually just got back from the dealer.I don't know why these rack and pinions are so weak......
Old Mar 23, 2012 | 03:17 PM
Mikeyyy816's Avatar
Mikeyyy816
Larry, I still haven't gotten to the dealer as of yet...it's going in about 10 days. Finally was able to get some good time off of work. I've been so damn busy it's been unreal. But I'll keep everyone posted when it goes in...
Old Mar 24, 2012 | 12:02 PM
LU229's Avatar
LU229
Hey Mike,
yeah i was wondering what ever happened about that.
It`ll be interesting in what they find and then do about it.
Busy, i hear ya bro, same here, no time to do anything i want to do.
Take care budd
LU
Old Mar 26, 2012 | 01:10 AM
72combo's Avatar
72combo
you should've went to the dealer when you had it back to stock
