2011 ram 1500 adding fogs
Old Mar 26, 2012 | 04:09 PM
5thcorps's Avatar
5thcorps
Default 2011 ram 1500 adding fogs
Would like to add a set of fogs to my 2011 ram. A typical wiring set up, 12v to relay trigger then lights will then be powered directly off the battery once the relay in energized and a switch is thrown. If I'm not mistaken, I believe these headlamps on the ram are pulse-width modulated. Can the positive side be tapped into to provide the 12v trigger to the relay, or will the pwm interfere with that?
Old Mar 26, 2012 | 11:52 PM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
Are you going to replace the bumper with a fog light bumper, or make your own holes? Or mount them underneath the bumper?
Old Mar 27, 2012 | 07:44 AM
5thcorps's Avatar
5thcorps
Going to mount them in the openings where the factory ones go
