Clunky dowshift arount 27mph
Old May 23, 2012 | 09:58 AM
cheapthrills's Avatar
cheapthrills
New Member
Default Clunky dowshift arount 27mph
Mine is a 09 ram 1500 hemi 4x4. In general has been a good truck but it did have a torque converter replaced at about 25000 mikes. Now at about 30,000 and when the truck downshifts at around 27 mph it a rather clunky band noticeable shift. Doesn't seem to do it all the time but certainly plenty of times. Can be make even worse if you hit the gas at just the time this is happening. Any thoughts on what is happening?
Old May 23, 2012 | 10:55 AM
DodgeCares's Avatar
DodgeCares
Cheapthrills,
I found the following TSB that was recently released. It involves a flash to the PCM that may help with your problem.
NUMBER: 18-011-12
GROUP: Vehicle Performance
DATE: March 15, 2012
SUBJECT:
Flash: MIL Illumination With Transmission And Driveability Improvements
OVERVIEW:
This bulletin involves flash reprogramming the Powertrain Control Module (PCM) with new
software.
MODELS:
2009 (HB) Durango
2009 (HG) Aspen
2010 (DJ) Ram 2500 Pickup
2009 - 2010 (DS) Ram 1500 Pickup
2009 - 2010 (DH) Ram 2500 Pickup
2009 - 2010 (DC) Ram 3500 Cab Chassis
2009 - 2010 (ND) Dakota
NOTE: This Service Bulletin applies to HB/HG/DJ/DS/DH/DC/ND vehicles equipped
with a 3.7L, 4.7L or 5.7L engine (Sales Code EKG, EVE, EZC, EZD or EZH) and
a 4 speed 42RLE or 5 speed 545RFE or 6 speed 68RFE automatic
transmission (Sales Code DGV, DGQ or DG7).
SYMPTOM/CONDITION:
The customer may experience a Malfunction Indicator Lamp (MIL) illumination. Upon
further investigation the Technician may find that any of the following Diagnostic Trouble
Codes (DTC's) have been set.
i. P050D - Cold Start Rough Idle
ii. P2181 - Cooling System Performance has been set
iii. P0935 - Line Pressure Sensor Circuit High All RFE transmissions
iv. P0300 through P0308 - Multiple and Single Cylinder Misfire. This condition can
occur when the vehicle is started cold and the driver immediately places vehicle in
drive and applies heavy throttle.
Driveability and Transmission improvements are also included with this software
release. These changes consist of the following:
a. Enhanced clutch protection for more robust torque management during repeated
fore and aft movement (rocking vehicle) all engines.
b. A revised torque convertor lockup schedule that will reduce transmission
temperatures in Tow/Cruise mode All models equipped with RFE transmission.
c. A Clunk sound or feel a shudder when the cruise control resume switch is pressed.
This condition is most noticeable after the brakes were pressed to cancel cruise
control and then the resume switch is pressed All models equipped with RFE
transmission.
d. A shudder or shaking feeling when a wide open throttle (WOT) event is performed
by the customer. This is most noticeable after the transmission downshifts during the
WOT event. This condition will stop once the transmission upshifts All models
e. A shudder or shaking feeling when accelerating from a stop under moderate throttle.
This condition will stop once the transmission upshifts All models equipped with
RFE transmission.
f. A shudder or shaking feeling after the transmission downshifts. This condition will
stop once the RPM's drops All models equipped with RFE transmission.
g. Harsh or noisy natural to reverse shiftsAll models equipped with RFE
transmission.
h. Harsh 4-3 downshifts. This condition happens when there is no throttle applied and
the vehicle is coasting down.All models equipped with RFE transmission.
i. Harsh 1-2 upshifts. This condition happens under moderate or heavy throttle
conditions All models equipped with RFE transmission.
j. Engine knock condition. This condition could happen when a wide open throttle
(WOT) event is performed or cruising at 5400 RPM or above All models equipped
k. Hard start or long crank condition at 0° F (-17° C).all 5.7L DS and DJ models
Reprogramming the PCM will correct the DTC conditions listed above
Old May 23, 2012 | 11:12 AM
LU229's Avatar
LU229
I`ve noticed with this flash update that people complain of loss in power and loss of mpg`s.
How much ignition timing are they programming out of these trucks anyway (????)
Also noticing a change in the shift schedule as well, after the re-flash.
My truck: 2010 Hemi Sport QC 4x4
I would love to get rid of the horrible shudder and hesitation when i floor my truck,
but i dont want to go backwards in power & mpg after the re-flash like others have had.
