Getting that cluncking feeling again....
Old Jun 18, 2012 | 12:05 PM
RAMULAK's Avatar
RAMULAK
Default Getting that cluncking feeling again....
Same feeling as when I had the front ball joints replaced at 9,000 miles under the old recall. Has 47,000 on it now. 2009 Quad cab Sport.
Feels/sounds exactly the same. Sigh.......
Old Jun 19, 2012 | 06:22 PM
Mikeyyy816's Avatar
Mikeyyy816
bummer man...replace them with some aftermarket ball joints, will probably last longer and you can get some with a zerk fitting.
Old Jun 20, 2012 | 08:46 AM
iskybantilus's Avatar
iskybantilus
i dont know about clunking but at 47000 miles front end seems to be getting loose on my 2009. i have been blaming it on lift/leveling kit but i wonder if parts are just wearing out like your saying.. i dont remember a recall on ball joints, do you mean the tie rod end recall?
Old Jun 20, 2012 | 08:34 PM
RAMULAK's Avatar
RAMULAK
Sorry. Duh...Yeah it was the tie rods that had the recall. Feels just like that again. I got the day off tomorrow and if it doesn't hit a 100 degrees again I might jack it up and check it out. If not I'll wait for it to cool down a bit outside. Yikes it is hot out there today.....Maybe my truck is starting to melt?
Old Jun 30, 2014 | 12:04 PM
SolarPLEX's Avatar
SolarPLEX
My ball joints wore out at 60,000 km stock. Had that clunky front end feeling. put a lift on, went to get the alignment and they said needs ball joints. Got ball joints on warrenty and did the alignment.
Now i also have clunky feeling again and its only been 20,000 km!!!
2.5" strut extension. and 275/65r20s.......
Old Jun 30, 2014 | 03:32 PM
Tazman40's Avatar
Tazman40
My 12 has a clunking in the front end now as well.40k on it,and i can feel it in the steering wheel.Replaced the ball joints a while back,and the pitman tie rod.99% sure its the drag link that doing it but i cant find anyone that lists a Moog drag link for a 2012 2500.Outer tie rods are tight yet but i moght just go ahead and replace everything thats left just so i can grease it all and be done with it for a while.
Old Jul 3, 2014 | 10:22 AM
DodgeCACares's Avatar
DodgeCACares
SolarPLEX,
I suggest following up with your Dodge dealer for a diagnosis. Mopar parts installed carry a 1 year warranty if defective. Depending on the diagnosis and when your previous repairs took place, your warranty may still be valid.
